Idle and throttle cables FXR
Old May 27, 2020 | 07:27 PM
Redrodyankneck's Avatar
Redrodyankneck
Default Idle and throttle cables FXR
Anyone know how long these OEM cables are?
idle 56337-83
throttle 56336-83
Old May 28, 2020 | 06:38 AM
Redrodyankneck
I found an OEM idle cable but it has a 90 degree bend, the cables on my bike are 45 degree. I must have after market cables. I have super E
Problem is that my idle cable is 36" long sleeve length with 2" inner cable throw. The throw needs to be 1.5". The barrel is loose as a result of being slack and binds against the carb body and throttle plate.
Anyone have pics of a good set up that works properly?
Old May 28, 2020 | 04:57 PM
JonB's Avatar
JonB
Don’t they do a s and s cable bracket that is taller so you can use the original kehein cables?
a search through the cci book should give the stock cable lengths
hth
jon
Old May 28, 2020 | 07:09 PM
Redrodyankneck
hth
jon
What is the CCI book?
Old May 28, 2020 | 07:24 PM
Redrodyankneck
I did find S&S catalog, page 169 Vintage catalog
open side 19-0432 $64.95
close side 19-0433 $64.95
They are proud of their cables.
Old May 28, 2020 | 09:15 PM
Joe12RK's Avatar
Joe12RK
look in that catalog for what they call a 'cable guide', and see if one of the variations will help your situation.
Old May 29, 2020 | 02:50 AM
JonB's Avatar
JonB
I’ve just had a look,
both cables measure at 33” for stock (this is the black outer length) and have a 130 degree elbow.
The ‘pull’ cable has a 5/16” 18tpi thread into the throttle housing and has 3 7/8” exposed inner.
The ‘push’ idle cable has a 1/4” 20tpi thread into the throttle body and has 3 3/4” exposed inner.
you do it need the taller cable bracket at the carb, the stock cables for a kehein butterfly are correct for an s and s. The taller bracket is to use a s and s with stock cables for a cv carb.
hope that helps
jon
Old May 29, 2020 | 04:42 AM
Hoginedgewood's Avatar
Hoginedgewood
J&P has very helpful people on the phone that speak English as their first language.
Old May 29, 2020 | 07:41 PM
Redrodyankneck
hope that helps
jon
I understood until that last line......taller bracket for both?? OEM carb shows the short bracket.
Old May 30, 2020 | 02:43 AM
JonB's Avatar
JonB
Sorry, I missed the error. You don’t need the tall bracket. The one you have will work
jon
