Spark plugs left out...help!
Old Jun 23, 2020 | 09:55 AM
Racepres's Avatar
Racepres
Originally Posted by JustDave13
Dude if you're worried about "dust" getting into your spark plug holes on any engine let alone a cast iron engine you need to hang up your irons.
BTW pathetic troll post
Iron Cylinders only... No Iron motors except Ironhead Sportsters and Knuckleheads..
Originally Posted by touchdown
few squirts of oil put the plugs back in and start. I would squirt some oil in any engine that has been sitting around for a while anyway.
Why???
If quality oils are used [difficult not to] the Lubrication is plenty strong, residual film strength for Extended Storage..
Never took one apart that was "dry" anyway!!
Old Jun 23, 2020 | 09:58 AM
IronAss's Avatar
IronAss
I remember running with nothing but a velocity stack. I seriously doubt a little dust is going to hurt an engine.
Old Jun 23, 2020 | 12:16 PM
Racepres's Avatar
Racepres
LOL
Back in the day... Humbolt, IA the Birthplace of Harley Drags... we used to actually put air filters ON...
How we learned the K&N "advantage"
Old Jun 24, 2020 | 08:26 PM
Drjoans's Avatar
Drjoans
6th Gear
Not trying to troll. As you can see from the brick...the bikes parked outside, under a tree.
I’ve read articles talking about how guys change up the oil system on these old bikes because the current setup doesn’t allow for a decent oil filter. Also said something about how dirt in an engine can get in between a piston and the wall then start grinding once it’s running.
two second google search, here’s the articles (article 4 is what I’m referencing):
https://shovelhead.us/pics/sheets/te...vels_alive.pdf
thanks for the help y’all.
Old Jun 24, 2020 | 09:35 PM
Tom Sarno's Avatar
Tom Sarno
2nd Gear
If you are worried then a squirt of oil is all you need. Even grains of sand will get coated and flash of as soon as it is started. You are imagining the worse case scenario where anything that might have gotten in has landed around the outside of the cylinders and is going to gouge the walls. Anything on the pistons will burn of and/or blow right out the exhaust.
Old Jun 25, 2020 | 09:36 AM
Racepres's Avatar
Racepres
I have personally put more miles on a Shovel with the old "horsehair" in-tank filter than any other bike or System... Maybe excepting the '83 FLHT with spin-on...Caution... it is Easy to get the wrong spin-on filter... less Microns Is Not the way for this application... I don't care what anyone says... I can Defend this
Old Jul 7, 2020 | 06:37 PM
JustDave13's Avatar
JustDave13
With the bike sitting outside I think rust would be my concern but not a big one.
DRBUICK
Milwaukee Eight (M8)
14
Feb 26, 2019 08:46 AM
cptdenny
2014-2024 Touring Models
13
Feb 6, 2019 09:43 PM
180Tiger
Oct 27, 2018 08:04 PM
TUFF LUCK
Oct 11, 2018 07:54 PM
straydog13
Ironhead
Nov 19, 2008 05:12 PM
