red alto clutch discs - and the steels with out the ball and spring and yes i know yours has the ball and springs - and a ram jet retainer for the clutch hub its under 10 bucks
John is ... Of Course, spot on...all accounts... but a Good cleaning has saved many a clutch pack for me...
I cannot say enough good about the ram jet tho...
I can't find a video of a ram jet retainer for the clutch hub. I'm not really sure what that is, or how to use it. Is that just the large washer I've seen online to keep the springs compressed
How are you cleaning the clutch plates?
I know less than **** about finding videos..There are a Jillion write-ups about the Ram Jet tho.. This one, http://www.laseur.nl/instructions/IN231596.pdf
is concise... Not long, dragged out, boring, ... right to the point!!!
I clean clutch frictions with mineral spirits and a stiff Brush... then dry thoroughly, [hang on the line] scuff up on smooth concrete floor and put 'er together...
paper in oil 30 plus years - this is what clutch material is - wont do the job for most if you try and clean them - but it works in a low performance app - many of the old timers will say they clean the discs and hot pail the chains - i dont have that much time left in my life to go after those ideas -- BUT it works for some
Careful John... All of us are Not Shop Owners!!! Squeeze that bitch till it Squeals, and get all of the life you can out of it!!!!
Changing clutches is Not Time Consuming!!!! And Especially these Days, ... Some of us may be short on $$$$
