Clutch ^%#@
Old Sep 30, 2020 | 06:03 PM
  #31
DooWop's Avatar
DooWop
Is that a crack running down the case?
Old Sep 30, 2020 | 06:47 PM
  #32
tld6008's Avatar
tld6008
That's what I thought when I pulled the cover but after close inspection it appears to be the result of some flaw in the casting mold or something. Its not OEM
Old Sep 30, 2020 | 06:57 PM
  #33
tld6008's Avatar
tld6008
Originally Posted by johnjzjz
they were bottoming out - reason they broke seen it many times as the 30 pack is depleting so are the brain cells
I debated for a while what the hell you were talking about... safety wire or springs. I selected springs. Still working on the 30 pack and brain cell reference
Old Sep 30, 2020 | 07:09 PM
  #34
johnjzjz's Avatar
johnjzjz
a bit of over analyzation - most learn how to fix a bike in a bar knocking them back - then you get to fix what happen and what they did
Old Oct 6, 2020 | 06:59 PM
  #35
tld6008's Avatar
tld6008
I broke the top of the solenoid when I had everything about buttoned back up. Can I replace this without removing the primary?
Old Oct 6, 2020 | 09:35 PM
  #36
sbrmike's Avatar
sbrmike
Unhook the wires and then two bolts holds the Solenoid to the Primary. Rebuild the Solenoid or Replace it.
Old Oct 7, 2020 | 06:02 AM
  #37
tld6008's Avatar
tld6008
I was wanting to know if the outer primary case needs to come off before I order a box of primary gaskets. The manual says yes but....
Old Oct 7, 2020 | 06:54 AM
  #38
sbrmike's Avatar
sbrmike
Just the way I said it. No need to remove outer primary.
Old Oct 7, 2020 | 07:24 AM
  #39
tld6008's Avatar
tld6008
Thanks
Old Oct 7, 2020 | 06:13 PM
  #40
tld6008's Avatar
tld6008
Well I got everything put back together today and the solenoid just clicks when I hit the stater button, battery is good but put it on charger anyway. This all started with my clutch problem and I can say that I have doubts if the problem is solved as I can't push the bike when in 1st gear with the clutch pulled. I set everything up by the book also.
