Ultima Ignition Programming Kit
Old Oct 8, 2020 | 04:56 PM
sbrmike's Avatar
sbrmike
My 1984 FXEF kick starts cold just fine with 3 blips on the throttle (stock Keihin carb) then one or two kicks, and then pull out the choke as far as needed depending on the temperature outside.
Old Oct 8, 2020 | 04:58 PM
Nick Sorgio's Avatar
Nick Sorgio
Good idea. I'll start it with e-start and get her warmed up and then try a kick start.
Old Oct 8, 2020 | 06:00 PM
Racepres's Avatar
Racepres
Originally Posted by garystaven88
I have this same ignition. Great ignition. I had it programmed for 0 dead revs. It will fire up 1-2 kicks hot. If the engine is cold, forget it. One quick push of the e-start and it fires right up.
Will work fine for a once-in awhile kick. However, if it were a kick-only bike I would not run this ignition...
Coming from a "points world" I love the Dyna-S... Hot? Cold?.. Kick starts just like a points set-up... But, Some Maintenance Required...
Old Oct 8, 2020 | 08:31 PM
garystaven88's Avatar
garystaven88
Yep. For a kick only bike that right there would be my only two choices: points or the S.
rouskie
Ironhead
Mar 20, 2017 10:14 PM
lagunatic
Shovelhead
Apr 10, 2011 09:17 PM
badinfluence63
Aug 8, 2008 10:07 AM
OneBlackFly
May 5, 2008 10:36 PM
SPILF
Oct 1, 2006 10:15 PM
