I keep replacing spark plugs?
Old Mar 8, 2021 | 01:46 AM
Liberty76's Avatar
Liberty76
5th Gear
Default I keep replacing spark plugs?
After a 1000 mile ride a year back, i parked up my 82 FLT and didnt ride it for a while for various reasons. When I did start it up, there was much backfiring and general rough running, definartely not ridable. So i initially put it down to bad fuel, so I pulled the Super E fuel bowl and cleaned jets, accelerater pump etc in my Ultarsonic Cleaner. All good, reassembled, but running just the same, so I changed out to a pre gapped new set of HD 5R6A plugs. Once done, all was sweet, running much better. I did a tune as best as I could on the carb, and went off for a 100 mile ride, no drama. I parked up for 24 Hours and returned home. Starts great, idles great, needed to idle for 10 min in a traffic jam straight up, and then she started running rough again. So I decided to change plugs on the side of the road, and all good again, rode home just fine.
So the plugs were pulled when i got home, and they looked the same as the others, pretty black, not oily. So rich, i guess. I cleaned up the previously replaced plugs and put them back in and they were chit, ran like a bitch, backfiring again.
So any clues as to why the plugs have been toasted? I get it that it may have been runing rich, but why are the plugs then unusable?
Dave
Old Mar 8, 2021 | 03:03 AM
vonh12's Avatar
vonh12
Running rich is fouling your plugs. Check your air filter is clean. Adjust your idle. and try lean out your mixture.
Could also try running a hotter plug.
Old Mar 8, 2021 | 06:31 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Harley OEM Plugs for an 82 Shovel is 5RL, 5R6AG, or 5R6APP may want to try a different plug than 5R6A. See Chart: http://www.harley-performance.com/ha...park-plug.html
Old Mar 8, 2021 | 08:27 AM
rockher_man's Avatar
rockher_man
Default Plugs fouling....
Accelerator pump adjustment.
Old Mar 8, 2021 | 08:38 AM
touchdown's Avatar
touchdown
Try a hotter plug
Old Mar 8, 2021 | 10:36 AM
Bass Player's Avatar
Bass Player
Did you change jets in the carb? Any motor mods at all? For me, I threw HD plugs away a long time ago. I went to Autolites and have never had an issue. My shovel runs best on them. I've also found that my bikes run best at a plug gap of .041. To each their own, you have some good advice above.
Old Mar 8, 2021 | 10:52 AM
Bubby's Avatar
Bubby
Agree with running autolite, my shovelhead runs best on them.
"Still here"
Old Mar 8, 2021 | 01:57 PM
Liberty76's Avatar
Liberty76
5th Gear
Ok, thanks fellas, I have some Autolites on the way. Though I still dont understand why if I clean up the previously fouled plugs, why they are now useless?
Old Mar 8, 2021 | 02:26 PM
johnjzjz's Avatar
johnjzjz
Because they dont make things to work forever anymore
you did not post what jets you were using a 70 main and 295 intermediate is what we would expect to find in it
while a agree that the acc pump could be rich and over squirting the engine - i tend to see this as a over rich jetting issue - coming if a trip and having a fouled plug unless it was stop and go
Old Mar 8, 2021 | 02:32 PM
Lowoilpressure's Avatar
Lowoilpressure
He road a thousand miles last year and the bike is fouled up this year.
So I surmise it’s not the plugs that are the cause. The plugs are the effect of another cause. If it were my bike, I would kick it. Then I would watch a YouTube video about the carb. Setting the fuel ratio, and all of that.
I’m not an expert but I did rebuild my carb last year and treated it as a new carb.
I don’t think your plugs are the problem. Too much fuel, timing. Something is fouling the plugs.
Tom
