Rear Cyl Rocker Box Gasket leak
Old Apr 30, 2021 | 11:53 AM
Scruffy 1's Avatar
Scruffy 1
Default Rear Cyl Rocker Box Gasket leak
83 Shovel. Old guy here, but a newbie. I just developed a rear rocker box gasket leak. I am going to replace the gasket. The front cylinder does not have any leaks. So. I am thinking just to do the rear cylinder for now. 30k miles and the engine has never been cracked opened. Compression Engine cold Ft: 90 psi Rear: 100 psi Spark plugs look good. Your thoughts
Old Apr 30, 2021 | 11:56 AM
johnjzjz's Avatar
johnjzjz
We see that as only changing 1/2 of your under wear -
your less then 20 bolts / nuts away
Yama bond 4 is all we use for that reason - nothing else works like it
Pwr
Mar 24, 2021 10:10 AM
MxNut
Jun 22, 2019 09:35 PM
RidemyEVO
EVO
May 5, 2013 09:38 AM
dayhunt85
Jan 26, 2013 01:52 PM
flat4fan
Aug 23, 2012 08:45 PM
