1977 FXE wiring Harness
Im helping a friend put back together his bike after his dad passed away, The bike ran great couple of years ago when i rode with him, however the wiring is a nightmare and before his dad passed away, removed almost all the wiring, no breakers, flashers, etc. I found a wiring harness from Dennis Kirk but its for 85 and later($200). The dash, looks the same, the ingnition switch looks the same. But you know how it goes, you buy electrical, you cannot return it. I have a manual, but would really like a factory harness with colored wirers. I have attached pics of my dash and the pic from Dennis kirk wiring harness. while i know not all the wires would be used, but saves a lot of time. The old points were upgraded to dual fire module years ago. ANy advice would be great.
The pic you posted from Dennis Kirk looks like a 3-light dash panel that was used on older models. And take a look at the position of the idiot lights on each. They are not in the same location.
On Softail and FLH models (pre-EVO) the idiot lights are for right and left turn signals, oil lamp, neutral lamp and high beam lamp. The 3-dash light consisted of neutral, generator and oil lamp indicator.
Your best bet is to make your own wiring loom. No 77 FXE model used the FLH style dash.
Something along the lines of this...
If you're going to use the 3-light dash you will also nee a 3-light style dash panel cover. And if you use it you have one light for neutral, one light for oil, and one light for your high beam.
Last thing, you want circuit breakers! They are necessary. It will ensure your bike doesn't fry and catch on fire if you have an electrical short.
I do All of my Wiring from scratch... using Only the Factory Color code.. but. Been at it for a Very Long Time. As an aside...I find the FL style Dash the very easiest to Wire..everything can Hide between the Tanks... or if a True FL...certainly a good Hiding place inside the Nachelle....
