If interested in watching the building of a performance engine I watched a YouTube on a boxer engine.
It's by a company called Subperformance. The name is for Subaru. The guy is building a 2.2 liter 1000 hp motor.
The motor was machined from a billet and the work was precise.
One thing the guy did was when the heads were torqued. His torque wrench had degrees on the readout. The bolts were tightened to a spec, backed off 180 and torqued in precise degrees of 90 then 70, then I think 20 deg
to gradually arrive to the spec.
I've torqued in steps but not measured in degrees.
It would be great to have a shop like his with all the special tools. I did know of a performance builder that did assembly behind glass and a locked door once but mostly not.
My understanding of shovels is specs need to have more tolerance with specs than later motors. That makes them a tad more difficult to work with. Something Donny said.
The guy building this motor replaces the studs with others. He talks about them. A manufacturer makes special for this hot rod.
But that's not what interested me. It's the way he approaches the build. A lot of people here have never done an overhaul or even a tear down. This is worth
watching just for the process. Then there's the tools.
Not much has really changed from what I remember being taught. Just more precision, better tools.
I think the build is in 4 parts.
I did learn a really different way to install wrist pins in pistons in a boxer. The problem is the crank isn't accessible. There's 4 holes in the block that the piston is aligned with and the pins and the
snap rings are put through the holes from the outside.
