Engine builders/machine shop work
Old Feb 13, 2022 | 11:18 PM
Zulu1's Avatar
Zulu1
Stage IV
Exclamation Engine builders/machine shop work
Who can tell me about Mel Bernstein (engine builder/restorer) who calls himself "Dragon Man" in Colorado Springs...I've seen some of his YouTube videos and his shop looks very impressive. Does he actually do good and professional motor rebuilds?? Is he reliable?? Does he warranty any of his work. I have an '84 ironed Sportster I'm restoring and I want the engine gone through from top to bottom....anyone have suggestions for reliable and reputable folks who do motor/machine work???
Old Feb 14, 2022 | 11:26 AM
John Harper's Avatar
John Harper
Have you called him and asked him these questions? That seems the most direct way to address your concerns.
Here's his phone number and business:
https://www.google.com/search?q=mel%...3vbK7HuKMU;mv:[[42.5487912,-68.0100819],[32.2177073,-121.9145183]];tbs:lrf:!1m4!1u3!2m2!3m1!1e1!1m4!1u2!2m2!2m1!1e1! 2m1!1e2!2m1!1e3!3sIAE,lf:1,lf_ui:10
John
Old Feb 14, 2022 | 11:32 AM
slw210's Avatar
slw210
Plenty of reviews on that guy.
Maybe check out some others.....
There is an Ironhead section on the forum HERE.
Old Feb 14, 2022 | 11:54 AM
slw210's Avatar
slw210
You might look around local to you as well.
I would recommend Squirrel as he is local to me and comes highly recommended. Squirrels Panheads Verdow Motorcycle Repair - Motorcycle Repair Shops, Motorcycle Parts, Motorcycle Parts Online
Or Facebook Squirrels Panheads - Home | Facebook
Wouldn't hurt to call him. I was there Saturday dropping off my starter for a rebuild.
Old Feb 14, 2022 | 12:13 PM
eighteight's Avatar
eighteight
FWIW:
XL transmissions require careful set up , measuring and selecting the right shims and shifter forks
Done wrong they can lock and blow up the trap door and or cases. It can be ugly and expensive
I would select someone with Sportster experience
Old Feb 14, 2022 | 02:48 PM
Zulu1's Avatar
Zulu1
Stage IV
He specializes in older Harleys and Sportsters....I read as much bad stuff about Dragon Man as I did the good stuff.....
Old Feb 14, 2022 | 02:53 PM
Zulu1's Avatar
Zulu1
Stage IV
...yes...I spoke with him Saturday....he talks just like he does on his videos.....sounds very knowledgeable and confident....his machine shop is awesome too...just had a lot of doubt thrown in when I was reading reviews....folks saying he uses a lot of foreign parts in his rebuilds while claiming to use mostly American....I read just as much bad as I did good about him....
Old Feb 15, 2022 | 06:12 AM
slw210's Avatar
slw210
You should really ask this on the Ironhead Forum. You might find somebody a little bit closer to you.
As for the one you asked about, I have seen some pretty bad reviews (also for the gun shop).
I prefer dealing with locals myself when possible.
Old Feb 15, 2022 | 07:12 AM
eighteight's Avatar
eighteight
Check out vids from Pro Twin Performance in Winder GA
Old Feb 15, 2022 | 09:19 AM
470004's Avatar
470004
I used Mel Bernstein once for some engine/tranny work when he had a shop in Amityville, Long Island, NY. The only problem was the valve job on my knucklehead. You needed a special jig which was different from Pan and Shovel. I ended up having the job redone at the HD. His shop did refund me back this cost, but that was after the third time I went back.
grbrown
EVO
48
Jul 29, 2019 08:12 AM
artsbest
Engine Mechanical Topics
Aug 16, 2018 10:55 PM
07bobber
Dyna Glide Pictures
May 27, 2013 08:21 PM
Saikia
Exhaust System Topics
Sep 12, 2006 12:31 PM
