Trans locked up !
Pics of the tear down so far. Oh and kicker, side some pics, not sure if the bent metal is normal. And I do have the FSM, will be reading it first.
Bruce
the clip is the 3rd gear clip well part of it
the counter shaft has to be pulled first the under the kicker stuff is 4 Allen bolts and remove the stay
you might have to beat it out if it seized the needle bearing — carefull dont miss and hit the trans case
I agree, pull the shift forks and that will tell the story of what you got. Sorry you went down . Be glad it didn't happen at a higher speed.
Ok, counter shaft is out. Shaft looks good, no marks that I can see.
Pretty sure the bearing cap was pooched by the punch driving the counter shaft out, needle bearing all clean and good condition.
I'm willing to bet these last two picks show the issue, but I could be wrong. That gear I believe should not be able to slide and the part of a retaining ring, that John identified, holds that in place,
So what do you guys think is the best move forward? Complete gear set or just replace the damaged gears. I will need at least one bearing and a retaining ring. Look forward to your thoughts
Bruce
Sucks but you are probably looking at a whole gear set and maybe a mainshaft. Seen them warp from that kind of hit before.
