Piston recommendations
Old Oct 18, 2022 | 12:11 PM
persuader219's Avatar
persuader219
Default Piston recommendations
Hello folks. My son in law and I are building a 72 FLH shovel head. We are currently working on the motor. It was previously bore .020 over. We’ve decided to take it to.030 instead since we are already going to replace the pistons with new ones. So my question to you guys is which pistons do you guys recommend? Cast, forged and hyper styled pistons. Also which vender should we get them from. Thanks
Old Oct 18, 2022 | 12:59 PM
magnum45pete's Avatar
magnum45pete
depends what ya want out of it,
if you want an understressed easy start plodder that will out live you, fit 7'5:1 low comp pistons,
but if ya want a bit of get up n go I'd go for WISECO 9'5:1 hi comp but not so much as to hurt the motor in anyway,....or stock Harley pistons with the correct oversize ...
Old Oct 18, 2022 | 01:09 PM
pgreer's Avatar
pgreer
For a fairly basic street engine, I'd bump the compression just a little and use cast pistons. I would try to not exceed 9-9.5 max.
Paul
Old Oct 18, 2022 | 02:32 PM
Policeking!'s Avatar
Policeking!
The best pistons I have ever had in my 1978 74ci, are Keith Black 8.5cr #263. I have put right at 50,000 miles on these, the three sets of stock pistons or the one set of Wiseco didn't come close to the kind of mileage. But that is just my personal experience over the last 45 years.
Scrmnvtwins's Avatar
Scrmnvtwins
Ive had good luck with Wiseco pistons and you can get them through Zippers all the way up to .080 over at 9.1:1
Old Oct 18, 2022 | 02:55 PM
Riceburnerfb1's Avatar
Riceburnerfb1
Forged Wisco pistons are ok for short term racing engines until they loose contol in the ring lands, then they require replacement in order to maintain performance.
A stock cast piston will have a longer life if not stressed into a performance situation.
Old Oct 18, 2022 | 03:05 PM
crb2855's Avatar
crb2855
I'd go for the 7.5 to 1 runs fine on regular. Oh yeah cast is fine too.
Old Oct 18, 2022 | 06:34 PM
johnjzjz's Avatar
johnjzjz
Pistons we use in the shop have been cast 40 years and today with the **** gas in this country we use the low compression 7 to 1 but use a moly top ring set in Hastings rings — the best cast piston in JCC but they dont sell any cast with that being an identifier
having said that any cast piston with do we have been setting the piston to wall at .003 for 25 years - yea the book said when ever but they wrote the book when leaded gas was available at the pump - that i not today
johnwesley
Engine Mechanical Topics
43
Oct 9, 2020 07:04 AM
lieutenant G
Exhaust System Topics
Jul 9, 2012 09:48 AM
onebad2
Shovelhead
Apr 5, 2008 11:32 PM
fryeca
19
Mar 2, 2008 10:01 AM
wuudbee
Jul 22, 2006 04:17 PM
