Need a solid guide on 80 fxs
Old Mar 9, 2023 | 04:00 PM
OneKickPan's Avatar
OneKickPan
Also at the end of all this, If I can get the bike looking somewhat like the one in this video I'd be ecstatic, the rear end looks lowered but it gives the bike a fantastic look.
I tried pulling off the sissy bar and it seems like its fixed to the struts, would I need all new struts and signal lights?
Also, I may just pass off the Keihn to a local carb guy in Wolcott, see if he can rebuild the thing for me.
Old Mar 9, 2023 | 04:05 PM
old mago's Avatar
old mago
if you lower the rear you run the risk of the final drive chain rubbing on the inner primary case and wearing a hole in it. Proceed with caution
Old Mar 9, 2023 | 04:41 PM
Uncle Larry's Avatar
Uncle Larry
I've seen more than few of 'em chew a hole in the inner primary ... Seen a few with a piece of steel riveted in to act as a "wear bar"
Old Mar 9, 2023 | 06:48 PM
OneKickPan's Avatar
OneKickPan
Alright, well I guess I'll pass on that then! Good to know!
Also, anyone got the lowdown on which foam tape to get for the front brake calipers?
Old Mar 9, 2023 | 10:15 PM
Joe12RK's Avatar
Joe12RK
The sissy bar mounting plates slip out from between the fender and struts when you remove the bolts. There should be a slot in the mounting plates for the turn signal wires so you don't have to disconnect. Harley put thick washers between the fender and struts on bikes without a sissy bar, you should do the same.
Old Mar 28, 2023 | 05:05 PM
OneKickPan's Avatar
OneKickPan
Any suggestions on a specific material I can purchase for the front brake caliper rattle? I've read people have used old fuel line, No idea what kind of foam tape to get either. Set the carb to a local guy, got a few week turnaround on that, so we'll have to wait and see how that turns out.
Old Mar 28, 2023 | 06:33 PM
pgreer's Avatar
pgreer
The Official HD Caliper Anti-rattle tape is described in Service Bulletin M-842. It consists of foam tape HD part number 44120-82 You must use two pieces per each calliper so you have to order 4 per vehicle.
You might try 3/8" thick by 3/8" wide closed cell foam window weatherstripping tape or something similar from a hardware store. Or look to see of the part from the service bulletin is available.
Paul
File Type: pdf
Old May 10, 2023 | 03:27 PM
OneKickPan's Avatar
OneKickPan
Guys, we did it. Sorry I don't have pictures at this point in time but I got the carb back from my guy all rebuilt and it looks SPANKIN new, every part on this thing looks brand new and the body is bead blasted clean, absolutely amazing work. Shout out to Carbs-R-Us in Thomaston CT!!
Now for the good news, the bike runs flawlessly! Took it for a rip down the road and back, got it up to third with no issues at all.
I've been lazy about the caliper tape since the carb was taking so long, so I still have to jump on that, the clutch plates on the other hand I will have to save for a rainy day.
Old May 11, 2023 | 04:33 PM
john lee's Avatar
john lee
Paul
my calipers dont rattle. no tape. i just use a smear of grease on the slider pins
Old May 22, 2023 | 09:22 PM
OneKickPan's Avatar
OneKickPan
I tried the tape, still have caliper rattle. It still feels loose at the pins, but the rotors are also old and could probably be replaced.
Also there is fluid leaking from the front brake master cylinder. I replaced the gasket, but it still leak.
Any suggestions on both those issues? After this the bike is good to go.
