Identifying charging system
Old May 2, 2023 | 07:28 PM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by sbrmike
The ones on the left are what was O.E.M. from mid 1970's to somewhere in the early 1980's. My 1984 O.E.M. is the opposite. That gives you the era. You don't need super high amperage. Cycle Electric is my go to brand. I hear rotors are pretty hard to find across the board. I put a used Cycle Electric Regulator / Rectifier and Stator from a 22 amp system (from my 1984) along with a stock rotor (1977) from a 16 amp system and it has worked just fine. As long as the Regulator and stator plugs match up is what you want more than anything; a 1980 FLH doesn't need more than 22 amps.
My experience has been way different. I had continual charging system problems with both the old 4 pin 17 amp and the later 22amp till I converted to the newer 32 amp setup. All the battery stupid went away and real peace of mind knowing I could find a regulator or stator at any indy shop when I was out wandering the countryside. Even ordering the older stuff is a pain anymore.
Isn't always about just enough for what you need.
Old May 2, 2023 | 07:30 PM
Slats1956's Avatar
Slats1956
Thanx Mike. Hopefully the system isn't toast. I appreciate it guys.
Old May 2, 2023 | 07:40 PM
TwiZted Biker
What happens with the older 2 pin is connection at the case gets lose and arcs burning out the socket or the wires off the stator hardened up, chip and ground out. These usually take the regulator out. Most common issues I've dealt with on the old girls.
Old May 2, 2023 | 09:36 PM
Slats1956's Avatar
Slats1956
Plugs both look right and tight , no damage. Gonna check the wires back to the stator when I test it.
Old May 2, 2023 | 09:44 PM
Slats1956's Avatar
Slats1956
Just noticed something weird when looking at the rotor . There is a thick heavy washer as well as a thin washer on the sprocket side toward the nut. That doesn't seem right to me . It has been converted to belt drive closed primary.Gonna check the case for rub marks as well as the inside lip of the rotor.
Old May 2, 2023 | 09:50 PM
sbrmike's Avatar
sbrmike
They sell or you can make a wire bent that uses one of the Primary bolts to make a hold -in for the plug. I too have burnt a few a pins off and fried regulators. Not a problem with new Cycle Electric stuff for sure, but if you can't find a complete Cycle Electric System, just use your old rotor and buy a 22 amp Cycle Electric Stator and Regulator / Rectifier if yours is bad. I don't think there is an easy way to test a Harley Regulator / Rectifier. The Battery and Stator can be tested and you can test the Stator and Regulator together. It has to be running. It should put out like 1,000 volts AC; the exact AC voltage is in the manual. If they all test good it is the Regulator / Rectifier that is bad is how we do it around here.
Old May 2, 2023 | 10:14 PM
Slats1956's Avatar
Slats1956
Are the Cycle Electric Guys direct sellers ? Or do You have to find a local distributor? Have not Googled them yet.
Old May 3, 2023 | 08:38 AM
Racepres's Avatar
Racepres
Yes...it is probably correct... the Rotors were cheapened terribly... thin at the spline now! So, the washers are there to 1) space the rotor for clearance (about .1washer on the Inside) then probably another .1, Plus..whatever it takes to align the Chain properly on outside of Rotor..
Edit; with a Belt...that alignment is More critical... align Carefully and Avoid belt problems down the road!!
I spend an inordinate amount of time, Aligning Belts, then close 'em up, and never see 'em again!!!!
Old May 3, 2023 | 09:16 AM
Slats1956's Avatar
Slats1956
O.K., that is making sense. Thick washer for thrust , thin washer for shim. Do I need to be checking the thickness of the rotor flange at the splined motor shaft? If so am I looking for a specific thickness? Bike was worked on at Daytona HD back in the 90's. Looks like sub par work and parts to me. Pulled off HD primary and replaced with CCI crap. Found an HD inner in my stash. The outer CCI cover bolts up but doesn't match the outline of the HD inner very well. Gonna replace motor sprocket seal while I have it torn down. The trans. main shaft seal is also seeping , so I will need to see if I can replace it with out the special ($$$$) tools. My brother is a rider not a wrench , and the work looked good to him. So here we go guys. Gonna rely on my experience from years ago and ask questions as needed here. Most of my work was done on generator style scooters back in the day. Thanx again for the help guys. Real happy with the forum so far.I need to get back to the bike and get off the computer , LOL.
Old May 3, 2023 | 09:22 AM
Uncle Larry's Avatar
Uncle Larry
Multiple choices ... Good Luck
https://www.google.com/search?sxsrf=...h=640&dpr=1.24
