Rod adjustment
Old Jul 7, 2023 | 07:55 PM
Hd47knuckle69's Avatar
Hd47knuckle69
Stage III
Default Rod adjustment
Just put the back head on. Heard you can adjust the rods in the same position
Old Jul 7, 2023 | 08:37 PM
ShovelEd's Avatar
ShovelEd
PUSH rods?
Pacific Mike is a living Goldmine of Shovelhead info.
Old Jul 7, 2023 | 09:03 PM
old mago's Avatar
old mago
solids or hydraulics ?
Old Jul 8, 2023 | 07:04 AM
Hd47knuckle69
Stage III
Default Push rods
Hydraulic liftters
Old Jul 8, 2023 | 05:26 PM
old mago's Avatar
old mago
when i replaced the head gaskets on my 82 flh this is how i did it, with both heads in situ torqued down to specs.....ive cut and pasted this from a previous thread HTHs.....my 1982 FLH has hydraulic lifters and this is how i do it which is how its done in the FSM , BTW ive never had any luck with the one up one down method , not saying its no good it works for some but not for me thats all.... this is what ive written in another post some time ago........
ok so i run hydraulics in my 82 flh. I have trouble with the rear inlet pushrod getting it out. like its been said here you have to drain the oil out of the lifter, and this can take some time. i have found the easiest way to do your hydraulic tappets is to remove them ,wash them out with some fuel, check that they are not scored , put them back together dry using the suggested paperclip to collapse them and make sure there is no oil in the lifter as well this takes a bit of doing as if you move the motor it will fill up again. I take all the pushrods out and place them in bags so you dont get them mixed up, then using the flywheel marks, set front piston at TDC on compression stroke. With the lifters all nice and dry(you can use a very thin smear of oil on them ) place the units with push rods in the lifters , now you should be able to with your fingers, to adjust the nut right down till she turns no more. I then mark one flat with a pen then turn out 8 only flats, then as you use one 7/16ths to hold use the other 7/16ths to tighten this action will take up one more flat to take the adjustment to 9 flats or 1 and 1/2 turns out. repeat for the back piston. This way works best for me.....also get the HD tool for checking
Old Jul 9, 2023 | 11:35 AM
Racepres's Avatar
Racepres
Good Post
That is the way I do it also... Can't screw up....
Old Jul 10, 2023 | 07:34 AM
Hd47knuckle69
Stage III
Default Pushrods
Thanks for your time
swhitinger
Nov 5, 2013 04:27 PM
munkymark
Shovelhead
Jul 4, 2011 07:53 AM
krh1326
Aug 13, 2010 10:15 PM
mk2007
Ironhead
11
Aug 1, 2007 12:27 AM
bonez
Harley Davidson Videos
Jan 21, 2007 12:36 AM
