shovel
Old Jul 3, 2011 | 04:39 PM
munkymark's Avatar
munkymark
Stage I
Default shovel
what is the tolerances for the rod endplay
Old Jul 3, 2011 | 06:31 PM
sqdealgeorge's Avatar
sqdealgeorge
Default rod end play
I've seen as much as 3/16 with no problem The up and down play is most critical You should feel nothing up and down (male /female rod )
Old Jul 4, 2011 | 07:53 AM
TwiZted Biker's Avatar
TwiZted Biker
That's one way another is put the wrist pin in and see if you have any twist in the front rod not side to side also the rear shouldn't have much if any side to side movement . To check the up and down like sqdealgeorge said rotate the front rod till its at top and pull up on it now smack the top if you hear a clunk rods are shot . The 3/16" in a 74 maybe in an 80" that'll throw wrist pin keepers if you have the good ones .
happyhab
EVO
11
Jun 10, 2016 12:01 PM
krh1326
Aug 13, 2010 10:15 PM
irondog
Ironhead
Feb 26, 2009 11:00 PM
straydog13
Ironhead
Sep 15, 2008 05:44 PM
bonez
Harley Davidson Videos
Jan 21, 2007 12:36 AM
