This is interesting to read. I have not noticed this with my Harley other than it smoking and puking a little oil after sitting for awhile, but still having plenty of oil in the tank. But I am dealing with wet sumping on a Norton Commando I have just acquired. On this particular bike the tank will fully drain into the sump in about a week. Nortons are notorious for this, and it seems to be related to aged oil pumps. If I am not going to run the bike for more than a few days, I will try to remember to siphon the oil into a large glass jar to be saved and reused, and put a “no oil” note on the bike. One problem with starting Nortons with a sump full of oil is excess pressure that can blow out the seal between the engine and primary…..is also the case Harleys?
Interesting about the Norton. The big twin Shovels discussed here like other big HD’s have a separate transmission that does not share a seal. Even Sportsters with the trans within the cases probably are well isolated from pressure cause by sumping & starting. I ought to look again at my XL shop manual…Many good answers here. Draining the oil as you do is the simplistic, effective work around. I’d wait until the last ride of the year, dump the oil, change the filter and leave a note to refill B-4 the first start up. Others can fill in what I miss.
I have a similar problem with a BSA M20 that sumps. I’ve replaced the Ball and spring that slowed down the sumping but didn’t stop it. It leaks onto the skid plate under the engine and I use a vet’s syringe and put it back in the oil tank. When I put it away for the winter, I’ll drain the oil tank. Kind of a pain but it is 79 years old and not uncommon. Maybe I’ve been lucky but none of my Harleys have sumped.
…..The big twin Shovels discussed here like other big HD’s have a separate transmission that does not share a seal. Even Sportsters with the trans within the cases probably are well isolated from pressure cause by sumping & starting…..
It’s actually engine oil getting past a seal and going into the primary case. The prudent thing to do seems to be to get the excess oil out of the case and back into the tank before starting the bike. I think it is only a problem when there has been lots of oil getting into the case. Nonetheless, from what you’re saying it doesn’t sound like this sort of thing is a problem with Harleys.
I haven’t heard of sumping & eliminating upon startup causing if the same seal issue you mention. Re HD if any unwanted oil is migrating to the primary it is because of a bad main seal - behind the alternator at the crank. Ruined a primary belt that way on a previous one.
Dumping the oil on the last ride of the season ( normally my last oil change) and refilling the following season is easiest.
Im 1400 miles away from my garage, escaping to FL during most of the cold weather and take only 1 of 3 bikes when I do. The cold up north here makes 50wt thickly-difficult and can drain heavily on the battery to turn over. Whenever I had to start a bike here in frigid weather I set a space heater aiming at the oil tank for 12+ hours prior. The Twinkie and Evo Sporty fare better starting in the cold.
