What Are the Best FLH OEM Style Shocks?
Old Jul 30, 2023 | 05:11 PM
WXSW's Avatar
WXSW
Default What Are the Best FLH OEM Style Shocks?
I’m looking to get new rear shocks for my 1980 FLH 1200. I want to keep the original look with the long chrome spring covers. What shocks do you recommend? The shocks that I will be replacing measure 12” from eyelet center to eyelet center (13.25” overall length). I would not be surprised if these are the original shocks. Apart from looking beat, when the spring preload adjusters are turned old road grime and sundry sedimentary gunk comes out of the holes of the adjuster covers. They are too soft and mushy, even with the spring preload maxed. I am hoping that new shocks will yield a better ride and less sag when cornering.
Thanks!
Old Jul 31, 2023 | 04:57 AM
stephtell's Avatar
stephtell
I'd be interested to know as well!
Old Jul 31, 2023 | 06:31 AM
MarkSG's Avatar
MarkSG
The answers you will get are what ever someone has bought is the best.
I run the Progressive on a couple of bikes and like them. They make a model 412 with chrome covers.
J&P also sells a replica set for about half the price.
tld6008's Avatar
tld6008
If I remember correctly most recent discussions regarding this topic (2-3 months ago) resulted in purchasing NOS items off Ebay. I also did the same thing about 2 years ago, the originals were made by Gabriel of Canada.
Old Jul 31, 2023 | 07:06 AM
johnjzjz's Avatar
johnjzjz
Progressive 412 - is the only thing i would use nothing else is better the ride is great - you will not be disappointed and they have a stock look to them
Old Jul 31, 2023 | 03:56 PM
WXSW's Avatar
WXSW
Lots of take off HD shocks on EBay. Are the J&P house brand shocks any good? They are inexpensive. Are they good, or cheap Chinese knock-offs? The Progressives ain’t cheap, but they’re cheaper than a set of Ohlins, et al., so really not so bad if they are high quality.
Another question: on a 4 speed FLH, is there an advantage to going with a longer shock, like. 12.5” or 13”? My bike has very limited cornering clearance, and that is with moderate riding. I feel that when I am leaning in a curve these old shocks are compressing too much and the bike sags and the floorboards start to grind. I am hoping that better shocks will help with that, but I am not opposed to going with a better length if it yields positive results, so long as it doesn’t change to look of the bike.
Old Jul 31, 2023 | 04:05 PM
touchdown's Avatar
touchdown
I have used the J&P's they were about the same as the OEM's in other words ok. I also I think when you put new shocks on you most likely won't grind the floorboards.
Old Jul 31, 2023 | 04:36 PM
TwiZted Biker's Avatar
TwiZted Biker
Front end needs more love than the shocks for that, 2" over tubes and cowbells with a progressive spring kit and 1/2"-3/4 extra spacer tube sticking out of the tube before you put caps back on. If she's old enough to still have the baffles in the tube caps remove them, useless. 30 weight non detergent motor oil instead of fork oil. Made my shovel wide glides a lot more rideable overall for my canyon habits.
Doesn't change the looks much and give you just enough riding height the dragging about goes unless you are getting real frisky. Rear shocks will help the overall ride but the front needs it more on the old girls.
Old Aug 1, 2023 | 12:43 AM
WXSW's Avatar
WXSW
Thank you for that! I’m going to look into how to do that for this FLH. More cornering clearance will make this bike so much better!
Old Aug 1, 2023 | 06:48 AM
johnjzjz's Avatar
johnjzjz
Progressive is the deal - when you buy junk china shocks - you get junk china shocks
e blows - OEM shocks are take offs because they are worn out and feel as if they have rocks for oil in them
we have put at least 100 pairs on in the shop - NO ONE - came back to complain what happen is a riding partner came in to buy a set also
yours would be the 12 inch set
