forward controls 1979 FXE
Old Aug 16, 2023 | 01:14 PM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by hellonewman
I was told by an ex dealership owner that HD cut that boss off so it wasn't easy to convert the less expensive model to forward controls essentially forcing you to buy a different model if you wanted that. True or not I dont know but wouldn't surprise me.
I can believe that, that boss and the entire mount crossmember is a cast piece. All I've run across look like they were sawed off as an afterthought. The angle left over on the frame has been different on every one of them. At a guess from past stuff I've done for production at car plants I'd say batch lots got taken to the bandsaw in the maintenance shop and trimmed before going to the line for assembly.
Old Aug 16, 2023 | 05:07 PM
Racepres's Avatar
Racepres
I will get a Pic of one that is here...I do Not see that... later year tho..
Old Aug 16, 2023 | 05:23 PM
john lee's Avatar
john lee
how did the plate that forward highway pegs bolt to bolt to the frame ?
Old Aug 16, 2023 | 05:27 PM
Racepres's Avatar
Racepres
Weldment... part of the front motor mount really...
Old Aug 16, 2023 | 06:12 PM
Tgm 52's Avatar
Tgm 52
2nd Gear
They have a flat bar stock welded across frame just above the upward curve with 2 threaded hole's to mount the highway bars too.
Old Aug 16, 2023 | 11:50 PM
sbrmike's Avatar
sbrmike
Originally Posted by Racepres
I do Not understand How that works... as the FXS and FXWG had the mounting boss...yet the FXE (et al) did Not..
I guess it makes sense that the MoCo would Drop that boss along with the introduction of the FXS..1977! Yet reintroduce on the "new" FXWG! 1980..
I think that the common thought back then was the MOCO removed the boss to keep people from faking Low Riders, but don't know that to be fact. I know that I passed on many a 1977 FX/FXE because of no boss. Pennsylvania Inspection stations frowned heavily on welds on motorcycle or car frames. Guys would title and register them at Ohio friend's addresses back then.
Old Aug 17, 2023 | 07:25 AM
Racepres's Avatar
Racepres
Actually, by my study, those are Castings (cast steel) that the Tubes "plug into" and then are welded to the tubes... But...yes... No Provision for Highway pegs on FXE after ??? what year??? I dunno...and, at that same time was the Pogo weldments eliminated??? I know that by 1982, they were eliminated...
Old Aug 17, 2023 | 09:26 AM
14GuineaPig's Avatar
14GuineaPig
My 1978 1/2 FXE did not have the tab. I had one welded on many years ago.
Old Aug 17, 2023 | 03:21 PM
Tgm 52's Avatar
Tgm 52
2nd Gear
Yeah that's what I'm going to do.
Emmons
Ironhead
Jun 15, 2020 09:30 AM
mark10
Feb 20, 2013 09:40 PM
Ironbarr
Jul 8, 2009 11:10 PM
Turbo Flux
Shovelhead
Nov 9, 2008 07:45 PM
JC Rider
Sep 25, 2007 10:31 AM
