Strange Question
Old Oct 25, 2023 | 08:16 PM
hellonewman's Avatar
hellonewman
Now that I read the article I see it may not be a Harley frame but I did see a pan in a softail frame last year on this site.
Old Oct 25, 2023 | 08:19 PM
hellonewman
Old Oct 26, 2023 | 06:39 AM
FL54's Avatar
FL54
Originally Posted by hellonewman
If you're stuck on the softail idea I get it but I second the FXR suggestion. I've had two, one shovel one Evo. Best handling Harley's I've had. I upgraded my front end to a 1200R sporty on both with dual modern front disc brakes. It stopped and handled but I preferred the Evo, its just a better engine and makes more power.
You forgot to mention how much you love your Twinkie.
Old Oct 26, 2023 | 07:13 AM
hellonewman
Everyone already knows, except Johnjzjz so I have to remind him now and then.
Old Oct 26, 2023 | 07:19 AM
johnjzjz's Avatar
johnjzjz
You neeed a shovel to bury a twinkie
Old Oct 26, 2023 | 07:23 AM
hellonewman
I must be doing something wrong. I have two shovels that need attention this winter but my TWINKIE is ready to go.
Old Oct 26, 2023 | 08:51 AM
johnjzjz's Avatar
johnjzjz
Yea you can just ride to the scrap yard it’s worth more at the scrap yard then selling it - but you could fill it with gas then its worth big bucks
Old Oct 26, 2023 | 10:31 AM
hellonewman
Same thing was said about knuckleheads at one time.
Old Oct 26, 2023 | 12:22 PM
Racepres's Avatar
Racepres
Originally Posted by Timberjkd
Hey guys had an idea. Been trying to find or build another shovelhead since I sold mine a few years ago. It was a kicker rigid and I loved it but it had to go. Im now in a place where I can get another project moving. Here's the question would a cone shovelhead 76 - 80 fit and work in a late 80s or 90s dyna wide glide? Was thinking of trying this because it would be a more modern set up...suspension controls brakes five speed...whats your thoughts? Anybody attempted this? If so pics would be appreciated.
I have never heard of a Pre mid '90's Dyna...But...to answer that question...Yes it will go...No Problem...Evo does Not drop into 4-speed Shovel frame...but vice vers?? No Sweat!!
Old Oct 27, 2023 | 06:24 AM
Architect's Avatar
Architect
The issue with a Shovel in a Dyna chassis is the transmission and oil tank. Dyna's have a oil and transmission pan under the transmission. How does that work out with a Shovel motor? IDK but would need to be worked out. My understanding is that in the 90's they only mode one 80" Evo motor, so the factory was putting them in rigid mount Softails and rubber mount Dynas and Touring bikes. Leads me to think the motor should be able to be bolted up to the rubber mounts with some effort. The Shovel motor is shorter than an Evo, so it should fit in the frame. The transmission and oil pan become the issue, good luck.
I have seen Genny Shovels in Softail frames, much easier route. But would be cooler in the Dyna frame.
