Strange Question
Old Oct 27, 2023 | 07:33 AM
johnjzjz's Avatar
johnjzjz
Old Oct 27, 2023 | 09:22 AM
Racepres's Avatar
Racepres
Originally Posted by Architect
The issue with a Shovel in a Dyna chassis is the transmission and oil tank. Dyna's have a oil and transmission pan under the transmission. How does that work out with a Shovel motor? IDK but would need to be worked out. My understanding is that in the 90's they only mode one 80" Evo motor, so the factory was putting them in rigid mount Softails and rubber mount Dynas and Touring bikes. Leads me to think the motor should be able to be bolted up to the rubber mounts with some effort. The Shovel motor is shorter than an Evo, so it should fit in the frame. The transmission and oil pan become the issue, good luck.
I have seen Genny Shovels in Softail frames, much easier route. But would be cooler in the Dyna frame.
No Problem... The Engine Dimensions at the Motor mounts , and Bottom are Same same.. Only the Top Motormount would need some minor Fabrication!!! Or replace with Shovel FXR (1982 and 1983 or FLT '79 thru '83, top mounts...
Old Oct 27, 2023 | 10:17 AM
Joe12RK's Avatar
Joe12RK
Also the bracket that connects the motor to the 5-speed transmission on those bikes, if it is not on the Dyna.
Old Oct 28, 2023 | 11:10 AM
Racepres's Avatar
Racepres
That "bracket" was Not on later 5-speeds... it is Part of the transmission, after???
Again...a Shovel Engine Swap into an Evo Dyna, or any Evo Platform, is No Sweat!!
Old Oct 28, 2023 | 01:52 PM
Timberjkd's Avatar
Timberjkd
This is a ton of useful info. Thanks everyone.
cmk0023
Apr 20, 2023 09:09 AM
‘05 Electra glide
Shovelhead
32
Sep 27, 2019 02:25 PM
docman
Shovelhead
May 11, 2016 10:46 AM
EricDial
Shovelhead
21
Oct 8, 2015 09:28 PM
Birddog416
Sep 12, 2013 01:43 PM
