Shovelhead installation
Old Feb 21, 2024 | 03:51 PM
Cliffw's Avatar
Cliffw
Default Shovelhead installation
How to install a complete shovelhead motor into a swingarm frame? ps I am doing this by myself.
Old Feb 21, 2024 | 04:56 PM
Joe12RK's Avatar
Joe12RK
It can be done alone, but it's not easy. Some people lay the motor on it's side and lower the frame onto it. Others make a jig to use a car engine hoist. Others install only the lower end and then install the jugs, etc in the frame.
Old Feb 21, 2024 | 07:33 PM
1981 suprglide's Avatar
1981 suprglide
well thing only weigh 188-pound lift it set it in the frame line up the four bottom bolts. then the motor mounts
Old Feb 21, 2024 | 10:01 PM
Spanners39's Avatar
Spanners39
Depends on the state of your back really....
Old Feb 22, 2024 | 06:14 AM
Architect's Avatar
Architect
And your age.....
Work smart, not hard.
Old Feb 22, 2024 | 06:30 AM
johnjzjz's Avatar
johnjzjz
Before you tighten any engine bolts make sure the inner primary does not influence the engine block mounting
its also helpful to know the year so real tip on the install does not brake **** before before you then ask how that happen
Old Feb 22, 2024 | 08:23 PM
Riceburnerfb1's Avatar
Riceburnerfb1
Tilt the engine in bottom first from the right side.
Old Feb 23, 2024 | 07:04 AM
Cobra1's Avatar
Cobra1
Lifting the engine with something is the smart way to go. Borrow an engine hoist from a friend. Save your back and you won’t scratch the frame. Here is mine ready for lifting and install. Super easy…..
Old Feb 24, 2024 | 12:01 AM
deathrowdave's Avatar
deathrowdave
I like layin engine on the side . Bolting frame to it and you and 2 Buds , pick up frame and engine
Old Feb 26, 2024 | 01:26 PM
RHPAW's Avatar
RHPAW
That.
I pulled mine to do the bottom end a few years ago. I don't recall doing anything particularly special, beyond using both hands.
