Here's another question for you all. Got the first head all lapped in and put the springs in. Poured gas in the combustion chamber. After twenty minutes the ports were still dry. After thirty minutes the intake side had about a half a thimble of gas in the port. Is this good enough or does it need to be lapped more?
Sometimes lapping won't give a 100% seal. The valve and seat may need to have a light cut to clean them up enough to seal. Also if the valve is a little loose in the guide then lapping or cutting may not be 100% either.
Lapping??? Never... maybe an expediant if Stranded!!!
Put a nice 3 angle job on...then Ruin it??
Not I
Look in the Original Service Manual for how it Should Be!!!!
BTW Even "new" valves get the Face skimmed/trued here!!!!
Not I
Totally agree.Lapping gets rid of the interference angle that is meant to cut the carbon and it actually seals better in the short time the valve is closed.Laping is for lawnmower engines.
I won't Lap Any Engine...But, I own the Equipment...Lapping will get ya home if Stranded, Maybe. If Over Lapped (i believe that is a Thing) ie Extremely Wide Seat.. yer gonna Burn a Valve...
If anything, I use Prussian Blus or some other marking fluid to detect low and high spots. But, that's after I cut the seats and valve faces to ensure they are true and the angle(s) is correct.
