Head bolts
Old Jul 7, 2024 | 05:27 PM
jeeperjo's Avatar
jeeperjo
Default Head bolts
Here's another head scratcher. I was torqueing the head bolts down on my 82 shovel and the washer split at 35 ft pound's. I used never seize on the bolts. Is this not good or should I have used oil? I dont think I hurt the threads because the bolt back out just like the others.Are stock washers not as good as colonies?
Old Jul 7, 2024 | 07:43 PM
Spanners39's Avatar
Spanners39
Did you oil the head bolt washers before assembly? you should do that as it stops false torque readings and other bad things.
Old Jul 7, 2024 | 07:57 PM
jeeperjo's Avatar
jeeperjo
Oh yeah. I oiled both sides of each washer. I set my torque wrench to step up settings so that I didn't take a chance on torqueing one too much more than another. I was concerned about the never seize. The factory manual says that what you are supposed to use. I didn't know if anybody out there had any problem with it before.
Old Jul 7, 2024 | 09:25 PM
Racepres's Avatar
Racepres
^^^ Hell I use Motor oil and treat it like the OE manual says to!!
Old Jul 8, 2024 | 09:30 AM
Joe12RK's Avatar
Joe12RK
I don't think the use of never seize vs. oil will make 35ft-lbs incorrect enough to split a washer. I think it's just a bad washer.
Old Jul 8, 2024 | 10:43 AM
jeeperjo's Avatar
jeeperjo
That's what I am hoping. I replaced it with a washer that came with some other head bolts I bought a while and it torqued down without any trouble. Thanks..
Old Jul 8, 2024 | 12:39 PM
jeeperjo's Avatar
jeeperjo
For anyone who's interested I managed to get the rest of the head bolts in just fine.
96hugger
May 12, 2024 10:36 AM
Scotty p
Flathead
15
Dec 31, 2022 05:03 PM
GLIDE50
Milwaukee Eight (M8)
24
Sep 16, 2019 11:13 AM
kino44
EVO
Jul 1, 2014 02:47 AM
justmealwatts
Exhaust System Topics
May 15, 2010 10:51 AM
