Now I need a Run, Brake, Turn module to go with it. There's a few different companies that make them, just trying to figure out if there is a certain one I need, or if there is like a universal option I can use. Because some of them are listed to fit certain bikes and others don't list any fitment info, so I'm assuming universal.
Yeah, so far all the ones I've found from Badlands don't list the older bikes in there fitment, not sure why. They may fit anyway?
The one I linked in the post looks to be universal, but I'm not sure.
They fit anything, I have a wiring diagram that I can email you for the 103, showing which wire does which task. You just need to run wires from your indicator switches to the module and the module to the flashers. You can wire the running lights from your tail light feed and bypass the badlands module.
They fit anything, I have wiring diagram that I can email you, showing which wire does which task. You just need to run wires from your indicator switches to the module and the module to the flashers. You can wire the running lights from you tail light feed and bypass the badlands module.
Alright thanks. Then I guess that Badlands ILL-01 above will fit. I'm message you my email.
