drive gears
Old Nov 3, 2024 | 11:33 AM
1981 suprglide's Avatar
1981 suprglide
hey twistzed is that a piece of outer primary with needle bearings
Old Nov 16, 2024 | 02:51 PM
DooWop's Avatar
DooWop
Maybe taking he derby cover off you could see something.
Old Nov 16, 2024 | 06:39 PM
1981 suprglide
no have to be mounted to observe it's happening with the derby cover on got to get a beat-up outer primary cut it down to see with the needle bearings inserted
Old Nov 16, 2024 | 07:12 PM
SparkyD's Avatar
SparkyD
Take a look see . . .
https://www.ebay.com/itm/25670516027...3A1%3Bchoc%3A2
Old Nov 17, 2024 | 05:57 PM
1981 suprglide
Originally Posted by SparkyD
thanks SPARKY D but this oversized bendix I've installed seem to be holding up, if this one fly apart I will be ordering one i guess it's stronger
Old Nov 23, 2024 | 07:06 PM
1981 suprglide
something I didn't notice before i can hear the bendix touch the ring gear only when I shut the engine down it seem the engine run backward about two strokes before it shut down and that's when it make contact with the bendix and eventually shatters it, is there a fix for this? the oversize bendix is still intact so far
Old Nov 23, 2024 | 07:35 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Sounds more like a ignition problem called kickback..
Old Nov 24, 2024 | 08:10 AM
1981 suprglide
well what you think cause that could it be cheap gasoline if it's ignition then I'm lost on repairing it
Chopper Nate
Jul 31, 2019 09:38 AM
tjg4036
Apr 3, 2016 05:26 PM
chromalox
Shovelhead
Mar 6, 2014 09:28 PM
el loco rico
Apr 15, 2013 03:01 PM
brdwgi
Classic
May 2, 2008 04:36 PM
