Burned up 72FLH
Old Sep 12, 2025 | 06:27 PM
  #41
68oramac's Avatar
68oramac
Originally Posted by Shovels & Vettes
I would think that ALL rubber parts in the engine would need replaced. And frankly, I would not stop at anything less than a full teardown and rebuild on everything. But....its your bike.
I think I’ll be getting by with replacing these external easy to get to seals cause the engine turns over and fires with compression.
Old Sep 12, 2025 | 06:41 PM
  #42
pgreer's Avatar
pgreer
Hard to know what seals were affected, but I'd be tempted to just replace all were exposed to the fire. For the oil line from the case to the rocker box and between the rocker boxes, just good quality heat rated vacuum line as @Joe12RK posted.
Paul
Old Sep 23, 2025 | 05:59 PM
  #43
68oramac's Avatar
68oramac
Default Hard cranking.
[img alt="I had the outer primary cover on with a few screws, sounded like crunchy steel cranking, slight cover movement,
did this to the clutch basket sprocket whatever it’s called breaking pieces off is there something seized inside the motor I wonder from the heat. There’s no kicker on this. I’m almost to the hopeless point. "]https://cimg9.ibsrv.net/gimg/www.hdforums.com-vbulletin/1500x2000/img_6879_68310cc84ee8757858a5b947413a4e538117f4e8. jpeg[/img]
I had the outer primary cover on with a few screws, sounded like crunchy steel cranking, slight cover movement, did this to the clutch basket sprocket whatever it’s called breaking pieces off is there something seized inside the motor I wonder from the heat. There’s no kicker on this. I’m almost to the hopeless point.
Old Sep 24, 2025 | 05:37 AM
  #44
Shovels & Vettes's Avatar
Shovels & Vettes
It will be up to your desire to get it running.....but I think you need to pull the motor out and disassemble it. Hard to say what is going wrong inside unless you look. Fire could have done things.....and I certainly don't know what, so if it was mine....its getting torn down and rebuilt.
Old Sep 27, 2025 | 07:13 AM
  #45
68oramac's Avatar
68oramac
It will be up to your desire to get it running.....but I think you need to pull the motor out and disassemble it. Hard to say what is going wrong inside unless you look. Fire could have done things.....and I certainly don't know what, so if it was mine....it’s getting torn down and rebuilt.
Starter nuts were hardly finger tight. In a half *** storage unit set up, home garage had burned, motel stay over three months now, will replace seals that were leaking, it’s an Ultima 96 inch engine only about 1000 on it. If the motor turns out fine keep moving along when time permits, still at my day job at 65.
Old Oct 27, 2025 | 05:23 AM
  #46
68oramac's Avatar
68oramac
Default Handlebar tree holes have contracted
I’m having a heck of a time pressing in the handlebar riser bushings: I guess the heat must have contracted after cooling reducing the sizing as shown, the top of the riser holes even somewhat smaller I don’t get it, but the bushings weren’t entirely seated inside of the riser holes of the tree, 6/10 of an inch poking out from the bottom. I’ve been pressing in from the bottom, using threaded stock and nuts.
I was stuck on a standard app using the phone so the photos look dumb. Got back to the mobile app.
Attached Thumbnails Burned up 72FLH-img_7014.jpeg   Burned up 72FLH-img_7013.jpeg   Burned up 72FLH-img_7012.jpeg
Old Oct 29, 2025 | 09:50 AM
  #47
s-glide76's Avatar
s-glide76
Thanks for keeping us posted on the progress.
But what about the 69 Camaro, did it survive?
Old Oct 29, 2025 | 10:58 AM
  #48
Shovels & Vettes
The triple tree is designed to position the bushings correct....i.e. they inside diameter at the top is smaller to act as a stop when pushing the bushing in from the bottom. And yes, the bushing correctly extends below the tree by the approximately 6/10 of an inch you mentioned. Mine are on my 72 FLH. As far as the actual dimensions....I doubt the heat would cause it to be smaller in diameter. They bushings are a press fit into the tree. I would make sure there are no burrs, or other restrictions to pushing them in from the bottom. It also could be the new "Chinese made" bushings are too large in diameter. If the fit is too tight...you will have to find a way to machine the ID to fit...or reduce OD of the bushings.
Old Nov 26, 2025 | 06:27 AM
  #49
68oramac's Avatar
68oramac
My Sun had not the means of keeping this and no purpose in it went to Copart, the motor transmission, LS and a five speed 600 tremec could’ve been yanked out, but he collected all on it.
Old Nov 26, 2025 | 06:31 AM
  #50
68oramac's Avatar
68oramac
The plasma cutter is on the lower left in the photo. Somehow, spark made its way back inside the rocker box caught the fuel on fire. He had walked into the house minute after. Absolutely no leakage that he or I knew of. I had that car on a rotisserie 16 years ago, much joy and progress over the years.
