Oil Pump Questions
Me, I bought an S&S Pump & the drilling jig and its perfect, I also bought a JBROSG oil Filter oil pump end cover, so the oil is filtered directly after leaving the pump, a great upgrade,
one thing i'd avoid like the plague is the SIFTON pump, as they are no longer SIFTON, Tiawan Ted & his V-TWIN MFG bought SIFTON and the quality now is *****,..as per all things he produces
Well, here's my next problem. I thought I'd be able to get away with reusing the oil pump but I took the last gear out on the scavenge side and found this. I'm assuming this is junk so I guess I go S&S for $500 since I bought all their other crap? Any suggestions? The feed side looks perfect.
thank you for the interesting photo of the "JBROSG oil Filter oil pump end cover", I wasn't familiar with this set, but it makes a good impression.
Videos about the assembly process can also be found online.
One further question is surely permissible: is the camshaft cover from the company "Burkhardt" still available new, or only as a used part?
Which magneto ignition would be suitable, Morris or Hunt? That would be another question...
Everything looks very "clean" in your photo. Is the oil filter a shorter version, and replaceable, with the built-in gearbox?
So many questions! How wonderful that there are forums like this with so many experts who know the right answer to every question...
Edit: One question remains, though: is it useful to have the oil filter so close to the engine? Wouldn't it be better, as is usually the case, to cool the oil filter specifically, as in the well-known aftermarket kits?
Mike
,... HOWEVER, I'M NOT SURE IF MID CONTROLS ARE USEABLE, i RUN FORWARD CONTROLS,..
I MADE THE FINNED HEAT SINK SLIP ON, TO HELP WITH ANY HIGHER TEMPS, SO FAR ITS ALL FINE,..
YES THE FILTER WILL JUST UNSCREW , IT IS CLOSE, BUT HAS BEEN DESIGNED TO FIT ,
THE BODY ALSO ALLOWS FOR THE OIL HOSES TO BE HIDDEN UNDER THE TRANSMISSION,...
IN MY HUMBLE OPINION HARLEY SHOULD HAVE DONE THIS THEMSELVES.
I USE MORRIS MAGNETO, RARE EATH MAGNET MAGNETOS, A BETTER SPARK & I THINK THEIR QUALITY IS FAR GREATER THAN HUNT'S,
BURKHARDT MAG COVERS ARE AVAILABLE NEW, BUT ARE REPO'S BY V-TWIN MFG, HAD I KNOWN I'D HAVE GONE FOR A DIFFERENT MAKE AS IT TOOK A FAIR BIT OF WORK INCLUDING WELDING OF A BURST THROUGH HOLE ON THE CRANK FEED GALLERY,.. OTHERWISE NOT TOO BAD FOR A TIAWAN TED PRODUCT
the oem filter is a part flow - part flow for a reason dont care what your Toyota has at 200,000 miles - the OP has found all kinds of bearish in the oil tank and the pick up for the pump is up off the bottom not because they thought is was better looking that way —- its a tractor engine treat it like that most did until the 80s came along and anyone with couple machines and no work invented $hit to sell does it work they didn’t care - it was shiny AND chrome so they sold them
I dont install chrome that was not on from Harley we put the bike out in the driveway with out those parts what ever they are - everyone knows i am woke and primarily concerned about their feelings ——- yea right
the oem filter is a part flow - part flow for a reason dont care what your Toyota has at 200,000 miles - the OP has found all kinds of bearish in the oil tank and the pick up for the pump is up off the bottom not because they thought is was better looking that way - its a tractor engine treat it like that most did until the 80s came along and anyone with couple machines and no work invented $hit to sell does it work they didnt care - it was shiny AND chrome so they sold them
I dont install chrome that was not on from Harley we put the bike out in the driveway with out those parts what ever they are - everyone knows i am woke and primarily concerned about their feelings - yea right
