Oil Pump Questions
Old Jan 4, 2026 | 04:13 PM
magnum45pete's Avatar
magnum45pete
Originally Posted by chizzler
I'm sure it will fit on the engine but I wouldn't be able to put my transmission in. The frame on the FLT is totally different. The engine and transmission are bolted together with a bracket. I don't have that downtube between them. The sender unit is on an angle so it clears if that tells you anything.
SORRY, I FORGOT THE FLT,.. A BIT OF AN ODD BALL WHERE AFTERMARKET PARTS ARE CONCERNED AND USUALLY COST A LOT TO CHOP OR CUSTOMISE,..
Old Jan 4, 2026 | 06:35 PM
johnjzjz's Avatar
johnjzjz
So are you're saying it's not uncommon to find sparkly stuff in the bottom of the oil tank? I know they get sludge in there but I would have figured the filter would remove most of the particles. Do the bottom ends usually make some warning noises before a catastrophic failure or do they typically just detonate? A lot of what I found may have come from the primary. I know what a magnet usually looks like when you pull it from an auto trans in a car. Like I said, the bottom end feels tight and it rotates smoothly. Today I'll put a dial indicator on the flywheels and shaft to see if there's any run out and I'll also put my stethoscope near the bearings and spin it to see if I hear any noise.
dont over think it they run for many years like you have with out cleaning the tank - we do it in the shop because of what you found - if the lower unit is snug like you found just treat it right and it will let you know when its time - again its a tractor like a bottle of jack when the last shot is gone you know
Old Jan 4, 2026 | 06:49 PM
Spanners39's Avatar
Spanners39
I pulled the oil tank yesterday and was definitely not happy with what I found. There was at least a 1/2" or sparkly sludge at the bottom of it. At this point, with all the other crap I've found wrong with this bike I have no confidence that the bottom end of the motor is going to last. Everything feels tight but I'm not sure for how long. I have a local guy I'm going to contact to see if he can do all the bottom end bearings, but if he can't I'm gonna stick that pump back in and wrap it up for now and see what happens. I have plenty of other bikes to ride so I'll be gentle to it while I gather all the tooling I need to do it myself next winter. I have plenty of other projects I need to get to and this thing is really holding me up now. The damage is on the scavenge side. The oil light never came on or flickered and the gears all look good so you might be onto something.
Flush and ride it, if it never dies then great, if it does, well, you were considering rebuilding it anyway.
Old Jan 4, 2026 | 07:39 PM
chizzler's Avatar
chizzler
Ok, I did do some measuring and it's all within spec. I also listened to it with the stethoscope and didn't hear any roughness in the main bearings. I'm gonna button it up when my cam shims come and let 'er rip. And, hopefully it rips and not R.I.P.'s
Old Jan 4, 2026 | 07:44 PM
chizzler's Avatar
chizzler
True. I have AAA and they'll tow any of my vehicles up to 100 miles so that's not really a concern. I'm more concerned about fragging the cases if it does go. That's why I was asking about warning signs. I'm pretty easy on my old girls so it'll probably be fine. It's not a huge deal to get the engine out of it again if need be. Thanks fellas.
bobhd77
Milwaukee Eight (M8)
Jun 16, 2021 06:55 AM
Turbojim
Engine Mechanical Topics
Sep 23, 2019 05:41 AM
panfisher2
Exhaust System Topics
Jul 12, 2011 02:31 PM
hdsmeden
Aug 30, 2009 06:30 PM
MikesDad
Aug 21, 2007 08:20 AM
