82 shovel cam
Old Nov 25, 2007 | 12:41 PM
mav7500's Avatar
mav7500
Default 82 shovel cam
what would be a good all around cam for a stock for now 80" shovel motor, and is the Andrews A grind a hydraulic cam, or for solids.
Old Nov 26, 2007 | 02:07 PM
HogBack's Avatar
HogBack
Default RE: 82 shovel cam
Hi Mav: My 81 Shovel, which is a .030 over,80 cubic inchhas the Andrews No.1. This is a low comprssion equal to the 'A' cam. So, for a 7:5 to1 compression it is a good street cam. Idle is not affected, and no head work needed, so I will say that the 'A' cam is the same. It has a little more duration and liftthan stock.
It is best to give andrews a call, and tell them what you plan in your build, how you plan to use it, and they will help make a good decision. You do not want to get a cam then find out the pistons, springs, heads, etc., will not work for what you want.
Good luck
Hogback
Old Nov 26, 2007 | 06:06 PM
ScooterHD69's Avatar
ScooterHD69
I don't think it matters whether you use solids or hydraulic. I run the Andrews A grind in my old shovel with solids. Runs very nicely, not a race bike but she will keep up with an Evo easily.
Like HogBack said though you would be well advised to give Andrews a call. I'm sure their tech guys can answer any questions you have.
Scooter
Old Nov 26, 2007 | 06:11 PM
mav7500's Avatar
mav7500
mine is a .10 over rebuild that is pretty fresh i am just tryin to wake it up a bit, so im glad to hear that the A grind will work well
Old Nov 27, 2007 | 04:41 PM
crampfan's Avatar
crampfan
Just get a "B" grind, ohsoooo much better than the "A" and if you want to run hyd. lifters they make a "B" for that too. I have used the "A" grind with hyd. lifter with no problem, but trust me, just get the B
Old Dec 7, 2007 | 01:04 PM
wbogley's Avatar
wbogley
ORIGINAL: crampfan
I agree with Cramp. I am running the BH(hyd. Andrews B). Still has a sweet raspy idle and I guess a little more power!!
Old Dec 10, 2007 | 08:47 AM
shovel78's Avatar
shovel78
I had an Andrews AB in mine and changed to a Crane 300H fireball and it really came alive.To me, Crane is the way to go.
Old Dec 10, 2007 | 09:53 PM
RonM's Avatar
RonM
I had a B grind in my first shovel.It had an S&S super B carb and some other work I am unaware of.IT had a dead spot with that bow leg maker carb,but flew like a rocket ship when you twisted the wick. I have a 84 inch S&S hot set upstroker motor now,its ok,but not like that old one
Old Dec 25, 2007 | 02:31 AM
cripula's Avatar
cripula
The A grind is a hydraulic lifter-friendly cam. I have on in my 81, which has been rebuilt and balanced with wiseco 9:1s (could be 9.5:1, it's been a while) and an S+S Super E. I tried a B grind (and solid lifters) but it lacked bottom and mid-range. When it came on it was great, but the power just came on too late. Bet it would be great in a 93". The A worked better for my current build.
IIRC, Andrews recommends high clearance valve collars for some years of shovels - mine was one of them.
Shovelpan80
Custom Models
Feb 25, 2015 09:16 AM
vittt000
EVO
Mar 25, 2013 12:13 PM
90evo
Dec 25, 2009 06:16 PM
softail99custom
EVO
Sep 12, 2009 01:26 AM
nzhogga
General Topics/Tech Tips
Dec 18, 2007 01:45 PM
