Shovelhead Head Reinstallation
Just had a valve job done and was wondering if there was a trick to reinstalling the heads? My main concern is how the pushrods are reinstalled. When I removed the heads, Iunbolted them, pulled them off,and the pushrods fell out. [:-]
Any advice is greatly appreciated!
BIGGEST thing to remember when putting the heads back on is to be sure that the odd hole, the oil drain hole, in the gasket is in the correct place. Snug the head bolts then cross torque to 65ft. lbs. After 250 - 500 miles retorque the heads, they will probably need it. I had to retorque mind 3 times.
Tip o' the day: Put your heads in place, head bolts in, tightened finger tight - should be able to move the heads. Install the intake manifold with the o-rings or rubber bands (depending on the year/manifold) rolled up out of the way. Do not install the manifold clamps yet. Move the heads so the manifold lines up properly, centered between the spigots. Tighten the head bolts to lock down your positioning. Roll the o-ring/bands in place. If o-rings, wrap with a light stretch 2 layers of Scotch 33 electrical tape over the installed o-rings. Install the manifold clamps. Torque the head bolts to spec. You might need to use a curved wrench to get to a couple of them. There is a tool that will do this with a torque wrench, but I never had one. (I have "calibrated" fingers - just ask THE MAMA.
) Install the pushrods/covers and do it right or you might end up with a bent valve, check the manual.Also, if the heads are inplace, will there be enough room to insert the pushrods?
I have never worked on this part of the motor
Thanks in advance!!!!
Hi all,
Yes get a good manual preferably by Harley. IMO
you have some good advice here and to add I would suggest after you lay out your cleaned push rods and tubes lay the push rods together on a flat surface and with your hand roll them back and forth and see that they are all straight and none are bent. While the push rods are all together stand them on end, one may be longer than the other 3- that fits front cylinder exhaust.
Inspect the push rod tubes for cracks, nicks or being bent and repair or replace. In your gasket kit you should have the corks for the tubes, some like to soak them in oil before installing them the last corks I installed I didn't oil and they fit good. Pay close attention to detail and don't get in a hurry when adjusting the valves with the spark plugs removed use your kick start lever to rotate the engine or better yet if you have a bike lift raise the bike put the transmission in 4th gear and roll the engine by turning the rear wheel clockwise from the right side of the bike. this gives you absolute control of the rotation of the engine. It you are in any doubt about setting up any part or your top end seek help! Its a pretty simple project but you can set your self up for problems if done incorrectly. Bent push rods or valves if not done correctly and if the intake is not set and sealed properly an intake leak can cause poor running and possible burnt valves.
Good luck and keep us posted
you need to know the brand of lifters-pushrods you have ( different manufactures adjust by a "per side" count and they all are different. also you need to positively identify your lifters - solid - hydraulic.
once those 2 factors are known you can start to adjust you lifters accordingly. let me know if you need help with this.
just my 2 cents worth.
