back fire
Old May 23, 2008 | 08:11 PM
1BADSHOVEL's Avatar
1BADSHOVEL
1st Gear
Default back fire
[:@] I have a 1979 shovel it has 96 stroker just put new top end back on installed it in bike starts but backfires through back pipe rear jug only prety bad like a gun shot adjusted pushrods set timing has points what could it be need help???????????
Old May 24, 2008 | 08:12 AM
Rodney's Avatar
Rodney
Default RE: back fire
Welcome to the HDforum 1bad..
you had a valve job done and new rings and pistons along with a bore oversize?
your doing what needs to be checked out.
Exhaust valve to tight
timing not set correctly
ignition falure of some sort
not getting enough fuel {lean condition}
then worst case bent exhaust valve
when you say the engine starts dose it start and run but back fire all of the time {every revolution of the engine} or only a few times?
I'm curious what bore and stroke to get the 96 Cu In?
what carburetor you running?
Old May 24, 2008 | 08:13 AM
AlCherry's Avatar
AlCherry
Inspect your coil closely to see if there is a crack around one of the posts, replace the condenser.
Old May 24, 2008 | 08:25 AM
sqdealgeorge's Avatar
sqdealgeorge
3 5/8 bore 4 5/8 stroke = 95.5 CI or 96
Old May 24, 2008 | 08:39 AM
Rodney's Avatar
Rodney
Thanks Geroge
Old May 24, 2008 | 09:06 AM
sqdealgeorge
How about something simple ! Manifold leak into the back cylinder ( rubber seal )
Old May 24, 2008 | 09:11 AM
Rodney's Avatar
Rodney
It usually is the simple things!
with an intake leak it may also be difficult to keep a steady low idle.
Old May 24, 2008 | 09:33 AM
GrayRider's Avatar
GrayRider
Exhaust leak?
Old May 24, 2008 | 11:07 AM
1BADSHOVEL's Avatar
1BADSHOVEL
1st Gear
he guys thanks for replying so fast it has new push rods also and a new condensor I tried 3 different ones I have another coil Ill try that It starts runs fine than start to back fire here and there espically if i give her gas at the trottle.
Fall_apart
Ironhead
Nov 28, 2013 08:16 AM
The Northern Bum
Jul 19, 2012 09:37 AM
Mugster
Exhaust System Topics
Oct 8, 2011 07:30 AM
lagunatic
Shovelhead
Feb 5, 2011 08:28 AM
Tltrump
15
Mar 30, 2008 08:52 AM
