need help checking clutch adjustment
Old Sep 7, 2008 | 07:34 AM
vetto's Avatar
vetto
So just replace the stock fibers with wet/dry plates and keep everything else...
Haven't tried the obvious test you mentioned ... seems like a no-brainer. I cant use the arm-starter measurement as I have an aftermarket tranny case.
Old Sep 7, 2008 | 10:45 PM
amfhd's Avatar
amfhd
I would definately replace the pressure plate with something besides the steel Harley one.They are not all that expensive.I am not familiar with a Tamer,maybe it is better than a Ramjet,but you need something to keep the clutch basket from moving side to side. As far as belt drives go,the ONLY time I ever broke down in 27 years on my Shovel was when my primary belt broke.The next day I put my chain drive back on.
Old Sep 8, 2008 | 09:05 AM
vetto's Avatar
vetto
Thanks amfhd! I love this place ... I would never find another place where I could glean so much knowledge from all you old-timers
Old Sep 10, 2008 | 01:01 PM
d_slat's Avatar
d_slat
here, if it turns out you want to upgrade to the scorpion, maybe this will save you a few bucks.
http://cgi.ebay.com/ebaymotors/BARNE...mZ370085282306
or otherwise these are the same wet/dry plates I put in mine. You may want to ask around about reliability, as I just put them in my bike recently.
http://cgi.ebay.com/ebaymotors/SHOVE...mZ360087447217
Old Sep 10, 2008 | 01:37 PM
vetto's Avatar
vetto
Thanks for the tips. I think I will go with a new set of wet/dry clutch plates, I have seen a bunch of brands/types that vary from $30-60. The scorpion and its peers are out of the financial realm of possibility at this point, maybe if I ever do a full remove and rebuild I would consider it.
Michaelbauduin
Jul 15, 2018 11:18 PM
Joshus41
Jul 24, 2016 09:59 AM
ffbuzz
Engine Mechanical Topics
May 19, 2014 09:34 PM
tonycap
EVO
14
May 24, 2013 11:44 AM
rgsamsel
Apr 21, 2006 12:41 PM
