83 FLHT rocker box removal
Old Oct 22, 2008 | 07:59 PM
Bridgeendfarm's Avatar
Bridgeendfarm
Default 83 FLHT rocker box removal
can it be removed from motor with out removing head or engine from frame? Last time I removed head and rocker box together
Old Oct 23, 2008 | 06:36 AM
sqdealgeorge's Avatar
sqdealgeorge
If you remove the front rubber isolator (remove stabilizers front & top ) jack engine up to remove the front rubber isolator then lower jack maybe you'll have enough room ?
Old Oct 23, 2008 | 08:18 AM
crampfan's Avatar
crampfan
cyl. head needs to come off, the rocker box is on studs. you might be able to fudge the front, but I doubt it.
89FLHTC
EVO
13
May 19, 2016 06:04 PM
tunlrat
Jun 24, 2015 11:37 AM
texashillcountry
EVO
Mar 25, 2012 09:33 PM
ACHALLIE
Shovelhead
Oct 1, 2007 07:59 PM
imboden
Classic
Jul 23, 2005 09:42 PM
