So I dont have 25 posts so I cant post in classified. So Ill try it here. If you are skeptical of my ID, check eBay. Same ID.
I don't have my Shovel anymore. I was moving stuff in the garage and found this box. its one of those forward facing aircleaners. THe filter is brand new. I never used this. It also comes with the DryCharger filter cover to keep things clean. I did do some stuff as i think I bought the freaking prototype. It is made to mount to the CV carb but included is an adapter to fit the S&S E. The elbow came polished but you could NOT get the bolts in. So I dd some sanding on the elbow to get the screws to fit.
I also found a valve spring to use for clutch spring compression, throw that in too.
Here is a pic of EVERYTHING. I am not breaking it up. I would like 40 bux shipped to the 48. if you live outside of that, we can figure something out.
