Solid lifters
Old Feb 22, 2009 | 10:11 AM
TazzinTroll's Avatar
TazzinTroll
Default Solid lifters
Someone I know wants to change to solid lifters He has a 78 shovelhead 1340 80". Any advice and how many flats to adjust?
Old Feb 22, 2009 | 10:31 AM
deadreckoning's Avatar
deadreckoning
If it is a kick start only, you need to keep it tuned or it's a byotch to start...
Old Feb 23, 2009 | 07:12 AM
sqdealgeorge's Avatar
sqdealgeorge
Forget the flats One adjusts solids as follows turn the engine slowly (kicker or trany in 4th gear rear wheel off the ground rotate wheel ) watch the pushrod go up than down at this position (bottom of the cam lobe ) adjust the pushrod so it rotates tightly in your fingers move on to the next pushrod do the same procedure Don't let anybody tell you that you can't run solids with a hydraulic lifter cam I did it for 40K miles on my 1979 shovel Flats are for hyd lifters !
800screws
EVO
31
Nov 6, 2016 12:48 PM
gnafin
EVO
Jul 28, 2014 07:18 PM
omgtkk
EVO
Feb 13, 2011 04:36 PM
blair
Jan 14, 2011 10:25 PM
dzawisto
Ironhead
Oct 7, 2008 01:30 PM
