shovelhead rubbermount question
Old Mar 23, 2009 | 02:40 PM
jlb61's Avatar
jlb61
6th Gear
Default shovelhead rubbermount question
Ok...this my seem like a dumb question but.....when did HD go to rubbermount for shovelhead engines?
Old Mar 23, 2009 | 03:46 PM
48pan's Avatar
48pan
Only dumb questions are the ones that aren't asked. 1980 FLT was the first one I believe.
Old Mar 23, 2009 | 03:55 PM
Jeff D.'s Avatar
Jeff D.
Not a dumb question.
1980 was the first year. It was on their FLT Tour Glide model.
I may be wrong, but, I believe this was the only model ever produced to use a rubber mounted Shovelhead. The other models remained solid mounted until 1984ish with the switch to Evo's.
The FLT was a first in other areas too. First to have a 5 speed tranny. First to use the FLHT style of frame that later replaced the FLH frame. Although it has had some small changes, it's frame design is still used on the baggers today.
Old Mar 23, 2009 | 05:29 PM
CamFX's Avatar
CamFX
There were a few 84 FXR models that were rubber mounted shovels. My friend has an 84 FXRT shovel powered.
Old Mar 23, 2009 | 06:40 PM
sqdealgeorge's Avatar
sqdealgeorge
All the above is true
Old Mar 24, 2009 | 05:54 AM
jlb61's Avatar
jlb61
6th Gear
Thanks..... I was pretty sure about the FXR but unclear about ant others. I suppose the FLT are pretty sought after now....thinking about a rubber mount shovel bobber/barhopper........project for winter..........
Old Mar 24, 2009 | 05:56 AM
shadylane's Avatar
shadylane
1982 for the FXR and 1980 for the FLT. Some were in late 84 or early 85 they stated to put Evo's in the bikes. I owned a 1982 FXR except for the stock charging system it was th most dependable bike I've ever owned. It had over 80,000 miles when I sold it.
Old Mar 24, 2009 | 02:40 PM
Jeff D.'s Avatar
Jeff D.
Actually it seems to be the opposite. They can usually be bought cheaper than the other FL's and even the FX's, with condition being equal.
They had some unique features that made customizing them harder than other models. They used a different gas tank that wasn't easy to switch out with fatbobs because of the different frame section above the engine. Their dash was odd too. It was built into the triple tree housing, and IMO, looked goofy if the fairing was removed.
Their exhaust was odd. Front cylinder pipe ran down the left side of the engine above the primary.
IMO they were a stepping stone for new Harley features to come, but to much of an oddball for people looking for a bike to start a complete make over on.
Old Mar 24, 2009 | 07:14 PM
legacycycles's Avatar
legacycycles
Oops
There not so hard to customize..Mine has more mixed parts than a Johnny Cash song.Its basically made the transformation to a 97ish Flht.Not exactly custom but it will defintley make you look twice if youre H-D savvy.
Old Mar 27, 2009 | 12:14 PM
ChiefGator's Avatar
ChiefGator
I have all the mods that you mentioned on my 82 FLTC. (Pics in profile) Some were done before me, some I did. The 96 RK tank was already done, and looking at it, it was a pain to do. The trees were a frankestein job, so I replaced them with a late model set and a RK nacelle. The forks and front wheel are from a 2000 EG to upgrade the brakes.
The FLTs are out there for a reasonable price. If you are willing to do some more work than bolting on a lump of catalog chrome, you can have a scoot like no other and not break the bank either.
tbonetony06
Dec 24, 2024 08:00 AM
jimjonesghost
Shovelhead
14
Oct 1, 2021 04:07 PM
82flh
Shovelhead
Jun 14, 2010 10:07 AM
safxdb
Shovelhead
May 19, 2008 08:17 PM
jo_k
Shovelhead
Aug 30, 2007 10:55 AM
