First rebuild
Old Apr 11, 2009 | 05:40 PM
pontiac80's Avatar
pontiac80
Default First rebuild
My bikes on it's last legs. I need to over haul the motor it's burning way to much oil. I never rebuild a bike motor before. I have redone a few chevys.
I'm trying to get a idea on much it's going to cost.
I want to up the comp to 10:1 and maybe install a cam. the thing I don;t understand is it's got 4 cams. dose comp cam sell all four for $156. And andrews is $400?
I see they have new Replacement Cylinder are they already to be used or do they need to be machined?
http://www.compperformancegroupstore...ry_Code=SHOVEL
http://www.jpcycles.com/Search/Produ...results=10&No=
Old Apr 11, 2009 | 08:29 PM
big cahuna's Avatar
big cahuna
The cams you list are for 2 different bikes. A shovel and a Sportster. What bike do you have? A sporty has 4 cams and a shovel has 1. Before you go changing cams you have to decide what your looking for in a cam, as well as where do you want the power. Do you want low end grunt, or top end pull like a runaway train?. you usally can have one or the other, but not both equally as strong. Go to Knightrider.com and read about cam specs and what power and where they make it. This way if all you want is a bar hopper, you won't put a top end cam that comes on at 4500 rpms and not be able to feel any difference over stock. Hope this helps.,,
Old Apr 12, 2009 | 09:21 PM
pontiac80's Avatar
pontiac80
yeah it's a sportster
it doesn't seem worth in to spend almost $400 dollars just to get the cam.
emperor wurm
Mar 10, 2017 04:41 PM
scottylonebull
Jan 19, 2016 07:28 PM
Skip
Exhaust System Topics
Apr 4, 2013 10:31 AM
Molarman
Dec 26, 2012 05:32 PM
GPHDXLC
11
Aug 5, 2010 02:38 PM
