81 FLH clutch handle
Old Apr 12, 2009 | 01:55 PM
krwilson830's Avatar
krwilson830
2nd Gear
Default 81 FLH clutch handle
Happy Easter all! How the heck do you get the cable end out of the clutch lever. I need to lube the cable so's I can ride this week! Thank you!!
Old Apr 12, 2009 | 05:27 PM
sqdealgeorge's Avatar
sqdealgeorge
Open the derby cover on the outer primary Release the clutch adj screw ( 9/16 nut ccw screw driver on slotted head ccw) until the clutch cable get loose at the lever You will now see how the cable is released from the lever pin Put a funnel around the cable end tape it tight to the cable for leakage Pour in WD-40 or light oil let it sit over night then reverse the procedure
Old Apr 12, 2009 | 08:26 PM
jmetro's Avatar
jmetro
DO NOT USE WD-40!!! its not a lube! something like dryslide, lubit-8, or a light OIL. wd 40 is more of a cleaner/water displacer. if you use it and nothing else your cable will be toast in no time.
Old Apr 12, 2009 | 09:47 PM
KT77's Avatar
KT77
Ah good to see someone knows wd40 is not a good lubricant. Only good for lubricating electronic potentiometers. Doesn't do **** for much else.
Old Apr 13, 2009 | 10:04 PM
jmetro's Avatar
jmetro
learned it the hard way 15 years ago with my first bike and the drive chain......... lasted about 50 miles after hosing it with wd........... lol. live and learn.
vessel
Nov 12, 2018 05:51 PM
All Aces
Feb 26, 2016 08:58 PM
boduke883
Jun 12, 2011 11:58 PM
Indy Road Dog
Apr 23, 2011 09:08 PM
00glider
May 20, 2006 10:58 PM
