While adjusting the clutch on my bike I have run into an issue removing the slack. Once I adjusted it in the primary I adjusted the cable. It was very spongy and did not feel right. I then loosened the cable again and can not get the slack out now. When I go one direction it gets more loose and the other way does not get the slack out, This is not the stock cable but a braided cable from the Harley dealer but may not be a harley product. I threaded it to the point it about comes apart and is still not taking up the slack. Any help?
inside the tranny trap door cover ( where the cable goes in) is a ball and ramp mechanism which converts the "pulling force" on teh cable into a pushing force on the rod which accuates the clutch.
your ***** may have slipped out of place--- get the cable as snug as you can and work the lever a few times slowly, then check and see if the cable can be further adjusted...you need to feel a positive resistance to the lever as you pull it.
this lever/ball/ramp thing is discussed in most service manuals
you slacken the cable
adjust the clutch
adjust the cable so that the lever action works the clutch smoothly
adjust the clutch
mike
Thanks, I was hoping I don,t need to remove that clip in there. I installed the cable and adjusted my clutch many times so I hope you are right and it can work itself out. I ll give it a try.
When you make the hub adjustment inside the derby cover it is easy to mistake a rough spot in the adjuster threads for the contact point on the plunger. Back off the lock nut and use a wrench to screw in the adjuster and turn it back out several times, then screw it in slowly to feel for the contact point and you should be able to get your 1/2 to one turn out easily when the true plunger contact point has been felt.
The disc that the adjuster is threaded into will lose the slight looseness in the clutch basket when the contact point is reached. If you believe you have reached the contact point but the disc still moves easily you haven't really found the contact point. Keep screwing the adjuster in until the disc is solid against the outboard side of the clutch basket. Then screw the adjuster out and in to find the contact point, and adjust from there.
can you damage the clutch cable if you unthread the adjuster too far? I unthreaded all the way and there was still too much slack, it was better but still way too much,
You can not adjust the clutch lever by the cable alone. You have to go inside the primary to adjust the clutch as well.
I think you are trying to adjust just the cable and lever.
Thanks but as I mentioned in my original post I loosened the cable then adjusted the setting in the primary but when I went back to take the slack out of the cable it would not adjust. As it turned out it was the push rod that was hung up. Once I backed out the set screw and push rod and re-inserted it adjusted fine. Apparently the push rod can hang up on the set screw so when you back it out the push rod comes back also. A little playing with it and it worked fine. A local HD tech suggested this so I thank him. Also thanks for your suggestions everyone.
there is a step in the clutch adjustment about pulling in the clutch handle a couple of times to reseat the ramp/*****. Then adjust cable end play at the handle using the cable adjuster. I use a dime for the gap.
Put the cable adjuster back together. Then go back to the clutch basket.
Loosen the jam nut on the clutch basket a few turns and then turn that Allen nut into the basket until it contacts the basket. Then turn it in some more and back it out.
Then go in for the final adjustment and turn the center Allen in until it hits the basket and turn it back out 3/4 of a turn and hold it there and secure the lock nut on the clutch basket without turning the Allen screw you just backed out. Then go back and take the slack out of the cable with the cable adjuster nut.
Pull on the clutch cable out of the perch until you see a gap the size of a nickel. Then squeeze the clutch lever a few times and check again.
