back brake light switch mount???
Old May 10, 2009 | 11:12 AM
781/2fxs's Avatar
781/2fxs
Stage IV
Default back brake light switch mount???
Where the hell does the Back Brake light switch mount on a 78 FXS. Im just about finished with her and this is just annoying me to death. any help or pics would be great thanks in advance.
Joe.
Old May 10, 2009 | 11:16 PM
FilthyLucre's Avatar
FilthyLucre
If I remember right. On my 79FXS, the rear brake line ran back to a T fitting mounted to the rear of the transmission plate. One of the plate hold down bolts also held the T bracket ( retangular piece that had two holes )and the T fitting was conected to that. A metal line than ran to the master cylinder and the third hole was for the brake switch.
Old May 11, 2009 | 07:34 AM
Rodney's Avatar
Rodney
That sounds correct.
if you are re plumbing the brake lines it could really go about any where so long as its between the master cylinder and rear brake away from the exhaust and out of the way so it won't get damaged.
Old May 22, 2009 | 01:15 PM
shovel52's Avatar
shovel52
I mounted mine on the tee right below the oil pump. I just picked a point out of the way and put it in. For all practical purposes, you could put it anywhere you can tap the hydraulic line. Ken
Dudepants
May 19, 2017 11:12 AM
elmo4fun
Shovelhead
25
Aug 27, 2015 06:54 PM
jokr
Sep 3, 2013 05:10 AM
RoadKingHellas
Jul 28, 2012 04:09 PM
mile hi
Jun 6, 2007 12:13 PM
