change back to points
Old Jun 10, 2006 | 06:17 PM
shovel78's Avatar
shovel78
Default change back to points
I have a fxs 1978 early that has an electrial ignition and want to change it back to the point set-up. What and how do i go about this. Thanks
Old Jun 10, 2006 | 09:20 PM
pococj's Avatar
pococj
Default RE: change back to points
Look in one of the aftermarket parts catalogs. Most of 'em have a kit that will do it. You'll need the backing plate, possibly advance mechanism, points cam, points, condenser, and possibly another coil. Some electronic systems used a different advance mechanism, but most used the stock one. Some coils aren't suitable for a points ignition as they have too high current for the points & condenser to handle.
Old Jun 12, 2006 | 01:03 PM
lennyeagle's Avatar
lennyeagle
you will need a coil with 5.23 ohms oem replacement xref number 31609-65a many companys make these a points conversion kit and recomended a set of blue streak points and condensor simply the best and worth the extra expence also u might want too replace the ignition wires while you are at it. havent done this in a while but this was a common deal changing back too points in the past.
Old Jul 10, 2007 | 02:29 PM
faziobrian@yahoo.com's Avatar
Stage I
Bike is hard to start cold (just started doing this). Bike is a Evo with only a kicker. Points ignition.
chrisislegend01
Ironhead
Feb 27, 2017 09:04 PM
lagunatic
Shovelhead
Apr 10, 2011 09:17 PM
hdbeggs
Feb 14, 2011 02:22 PM
SPILF
Oct 1, 2006 10:15 PM
98kingflh
Jul 9, 2006 05:02 PM
