crankcase vent
Old Dec 27, 2009 | 12:21 PM
Big Dave's Avatar
Big Dave
Default crankcase vent
I have a 1980 fxef stock 80 cu in on lengthy shut down my cc vent starts to weep oil i was wondering if oem hook up would have this vent hooked up to the carb backing plate i am running a s&s super b carb and was thinking of doing this if it would not cause a problem
tks in advance for any info
Old Dec 28, 2009 | 09:13 AM
AlCherry's Avatar
AlCherry
You are "supposed" to hook up your breather to the carb backplate to recurculate your crankcase gasses back through the motor to be burned. I wouldn't do it due to the fact that the shovel will puke oil into the carb foul things up, leak oil all over the motor and clog the air filter.
Old Dec 28, 2009 | 09:18 AM
sqdealgeorge's Avatar
sqdealgeorge
I don't like the vent line hooked up to the air cleaner Can be a mess oil soaked air filter etc etc I use a Unifilter 3/8 hose connection and run it down low If a bike sits long enough the tank oil will migrate to the bottom end and when started up the oil has to get out I have put vice grip pliers on the oil feed hose from the oil tank to the oil pump feed This does stop the oil migration BUT The pliers should be painted bright yellow just so you remember to get the pliers off before you start the bike ! duh
Old Dec 28, 2009 | 10:11 AM
Big Dave's Avatar
Big Dave
thanks for the info
my next question would be how do i get the ball check out of the oil pump to clean and inspect it ?
Old Dec 29, 2009 | 08:04 PM
Big Dave's Avatar
Big Dave
Just a follow up i have hooked up the vent line to the air cleaner but i put a drain **** in at the low point with the idea when i see oil at the carb i will drain the tube
You have to understand i am **** about oil leaks and take great pride when someone says you must be out of oil your shovel is not leaking i know it can be done
firehawk6
Sep 16, 2017 03:31 PM
hpw2406
May 8, 2017 08:17 PM
elevmike
Oil Archive (no new posts)
Jan 7, 2012 02:34 PM
Maxattack
General Topics/Tech Tips
Apr 26, 2008 09:02 AM
Missouri_Ridge_Rider
Aug 10, 2007 05:54 PM
