oil pump
Old Dec 28, 2009 | 11:25 AM
Big Dave's Avatar
Big Dave
Default oil pump
How do i get the ball check valve out of the oil pump to clean and inspect it it is on a stock 1980 80 cu in shovel
Old Dec 28, 2009 | 05:41 PM
sqdealgeorge's Avatar
sqdealgeorge
Look at the pump right side looking to engine the top of the oil pump has two slotted screw heads You want to tackle the screw head close to the right case The high tower on the right away from the right case just say no you want the tower toward the right case that is below the other tower ! A manual would show you what I am saying anyhow remove the top slotted screw grab a magnet pull out the spring then pull out the ball bearing now take another ball bearing insert tap the new bearing lightly to re seat take out that ball bearing and drop in a new one close it up After all this oil from the tank will still migrate through the ball check to the bottom end But oh well you gave it hell ! maybe some member will show you a picture and an arrow to the slotted screw to remove !
Old Dec 28, 2009 | 06:05 PM
Big Dave's Avatar
Big Dave
Thanks sqdeal
i have the spring out but cant get the ball i'll see if a buddy has a stronger magnet
tks again
Old Dec 30, 2009 | 06:55 PM
FilthyLucre's Avatar
FilthyLucre
I usually attach the magnet to the side of a screw driver or flat punch and it will magnitize the punch enough to pull out the ball.
Old Dec 30, 2009 | 08:20 PM
Neil74's Avatar
Neil74
You can also wrap a length of wire around a screw driver or punch and hold the ends to the posts of a battery. Take the tool out of the wire an instant magnet.
pilot1996
Oil Archive (no new posts)
Nov 14, 2021 07:05 AM
smnort
Shovelhead
Jul 5, 2013 10:01 PM
JohnB445
Shovelhead
Mar 15, 2008 06:31 PM
hotrod351
EVO
11
Aug 11, 2007 05:13 PM
