Raked trees
Old May 1, 2010 | 06:00 AM
51spanky's Avatar
51spanky
3rd Gear
Default Raked trees
Thinking about putting a set of trees with built in rake on an 80 FXWG. Has anyone used these? Problems? Pros or cons? I'm sure this has been discussed before, just can't find it.
Old May 1, 2010 | 08:21 PM
pococj's Avatar
pococj
In general, raked trees are to correct the trail on a bike that has had the frame raked. They have been used by the MoCo on certain models to get the trail dimension to where they wanted. Using them may cause no problems, as long as the decreased trail remains in the region required for stability. If that trail dimension gets too small, then you are looking at a high speed tank-slapper of a wobble. And you may ride a long time before having one set off by a particular set of riding circumstances. Do your homework and determine the trail before going this route. I can speak from experience that a tank slapper does little more than cause you to suck the ***-seam of your jeans so far up into your rectum that you won't need to wipe for 90 days. And that's if you're lucky.
agiffey
Jun 15, 2012 12:58 AM
dyna rider
Feb 17, 2009 07:33 PM
bobbsterkid7
Sep 28, 2007 09:02 AM
harleyvato1963
Aug 27, 2007 06:29 PM
DynaDogg
Aug 26, 2005 11:35 PM
