But yet another clutch issue
Old Jul 2, 2010 | 12:33 PM
AlCherry's Avatar
AlCherry
If it still lurches after you get it back together, your problem may be the fiber plates themselves. The aftermarket plates you have in it maybe wet or dry plates and needs to be soaked in oil for a few days to get them "wet" enough to grab properly. I ran into this problem a few years ago with the Barnett Kevlar fiber plates when they first came on line.
Old Jul 4, 2010 | 06:02 AM
Shane Hutchins Sr.'s Avatar
Shane Hutchins Sr.
I'm jumping in alittle late but, put a basket retainer in. It basically replaces the bearing retainer and springs. Took me all of a half hour to install. There are two types, a Tamer for aroung $80. or a retainer for around $20. The Tamer looks like it will last longer as the retainer is a compound material (plastics). This will help keep the basket from drifting on the hub. It made a huge difference on mine so comes highly recommended. Thanx again sqdealgeorge.
Old Jul 6, 2010 | 03:03 PM
Staggerty's Avatar
Staggerty
Stage IV
I've had lurching problems for years on my 83 FXR. It was always pulling when sitting at lights. Finally found a guy who recommended a little gizmo called a RAMJET. Had it installed and clutch works better than ever, and I have been riding this bike for 25 years.
Old Jul 7, 2010 | 02:04 AM
dunnth's Avatar
dunnth
4th Gear
hey guys sorry it took so long to repy, however put the new hub disk in and reinstalled (took way to long because of that damn primary chain, i just couldn't get it on the basket) but after i got her all back together and took her for a test drive MAN!!!! what a difference. of course i had to readjust the cable and pushrod. but the end result is awesome. it dosent lurch at all. so hopefully all is well now!!
(for all those that dont know- that hub retainer nut is reverse thread. just in case)
My only issue now is that damn oil bath chain. ive tried everything and it still leaks. i guess its just the nature of the beast.
thanks again you guys are great!!!!
Old Jul 25, 2010 | 07:43 PM
chriscujoscreech's Avatar
chriscujoscreech
Stage I
Default Seal it!
Seal that inner primary! Why would anyone want to run oil that's been in the primary case through their motor? HD figured it out in the mid '80s. After the oil bath is shut off, just add 5 oz. of oil in the primary. That will keep the primary chain lubed, and keep the clutch gunk out of your motor.
Hey Man
EVO
11
Jul 8, 2017 03:28 PM
TRacer
May 24, 2011 11:50 AM
dunnth
Shovelhead
Jun 30, 2010 02:03 AM
bigkylewhite
Jul 25, 2006 01:32 PM
bigkylewhite
Jul 14, 2006 08:49 PM
