Pops out Carb
Old Jul 26, 2010 | 02:46 PM
TA Motorsports's Avatar
TA Motorsports
2nd Gear
Default Pops out Carb
I have a 79 FLH 80 CI that pops out the carb around 2200 rpm I have cked compression 100 lbs Changed spark plugs Set the air gap to 0.004 set timing and rebuilt carb any suggestions?
Old Jul 26, 2010 | 02:52 PM
TwiZted Biker's Avatar
TwiZted Biker
need a little more info , what carb , pipes you running and when did this problem start ? What changed to kick it off ?
Old Jul 26, 2010 | 02:59 PM
TA Motorsports
2nd Gear
It has the stock carb Keihn pipes are 2 into 1 with a fish tail has baffles no idea when it started I'm looking at for a friend who's husband passed away
Old Jul 26, 2010 | 03:17 PM
AlCherry's Avatar
AlCherry
Without more info, the issue could be anything from a intake leak, midrange jet too lean, a short in the ignition wires, to a broken valve spring.
Old Jul 26, 2010 | 05:14 PM
TA Motorsports
2nd Gear
I have cked for a leak by spraying carb cleaner around the intake ect, it only pops at around 2200 rpm so I would say a short would not only be at 1 rpm, both cyl were the same comp so wouldn't that rule out a broken valve spring ?
Old Jul 26, 2010 | 05:15 PM
TA Motorsports
2nd Gear
I forgot the spark plugs were black so i wouldn't think too lean
Old Jul 26, 2010 | 06:07 PM
Neil74's Avatar
Neil74
What air gap is set at .004, the plugs? Does the bike have points and condenser or electronic ignition?
Old Jul 26, 2010 | 06:18 PM
TA Motorsports
2nd Gear
The air gap is on the Sensor for the Electronic Ignition
Old Jul 26, 2010 | 06:23 PM
Neil74's Avatar
Neil74
Ok my confusion, I don't run them fancy new ignitions.
Old Jul 27, 2010 | 10:05 AM
83 fxdg 90's Avatar
83 fxdg 90
based on your black plugs
back plugs = fouling rich
put a new set of plugs in.
if the problem goes away you need to change spark plug heat range carb jetting or both because it will be jest a matter of time till the new plugs foul
back plugs = fouling oiled if shinny
rings or guides shot
my bike would start to foul plugs a low rpm so i would give it hell and the problem would go away but would return each time worse and sooner than the last.
if i let the bike warm up using the ss carb inrichiner buy the end of the day the plugs are fouled
to fix my plug fouling problem i only use the ss carb inrichiner to start and the throttle lock to keep it idling till warm
switched plugs to http://www.ngksparkplugs.com/product...m.asp?mode=nml
