79 FLH Ignition points
Old Aug 1, 2010 | 06:36 AM
HD47knuckle's Avatar
HD47knuckle
Default 79 FLH Ignition points
I need help on how to set the points on my 1340 cc shovel. Orignally had electronic ignition and the factory manual does not cover setting points. Gratful for any help. Thanks
Old Aug 1, 2010 | 08:34 AM
sqdealgeorge's Avatar
sqdealgeorge
Set the points to .018 on the narrow lobe ( highest point ) Now rotate the motor to the fat lobe again this should be set at .018 plus or minus .002 You accomplish this by using a small plastic mallet and striking the nut head that holds the ign cam to the pinion shaft Sound crude doesn't it You tap the nut head to move the cam upward to open the points more or downward to close the points more Now comes the timing part if you need help on that let us know You always time on the front cylinder compression mode
Old Aug 1, 2010 | 04:29 PM
HD47knuckle
Default Points
Thanks for the info. I appreciate it!!
Old Aug 13, 2010 | 04:01 PM
FLYING's Avatar
FLYING
When I do not have a kicker to turn the engine over I pull the plugs and have the bike in gear and roll it to get the point cam in the right spot.
pnwsurveyor
EVO
Sep 18, 2018 06:43 PM
98hotrodfatboy
Aug 22, 2018 01:48 PM
gansengansen@gmail.com
EVO
15
Nov 9, 2016 11:48 PM
hrly762002
General Topics/Tech Tips
May 18, 2013 10:43 PM
CTP
Ironhead
Sep 7, 2007 01:13 AM
