compensating sproket nut
Old Sep 16, 2006 | 01:22 AM
bikerbehaviorist's Avatar
bikerbehaviorist
Default compensating sproket nut
I bought a JIMS block to lock up the chain and sprocket and thought I might be able to bust this thing open, but no!
I guess first things first - is this a reverse threaded nut or not!
The tool says do not use an air or electric impact should I listen???
Old Sep 16, 2006 | 01:58 AM
panz4ever's Avatar
panz4ever
Default RE: compensating sproket nut
The motor sprocket nut goes on and off as a normal thread; the nut that holds the clutch housing and plates is a reverse thread. I have used an air impact wrench to remove and install both parts. The only thing you have to check is to make sure that the lockwarsher on the clutch hub does not slip (it has that dog ear tab).
Old Sep 16, 2006 | 12:38 PM
JAMES2's Avatar
JAMES2
ORIGINAL: panz4ever
[sm=exactly.gif]
Old Sep 17, 2006 | 02:55 AM
bikerbehaviorist
Thanks! I guess I have to buy and impact wrench........
Old Sep 23, 2006 | 04:52 PM
daveman's Avatar
daveman
There are several options:
1) buy impact wrench, borrow impact wrench
2) try taking the comp nut off using cheater/extension bar to get more leverage
3) Take bike down to corner gas station...and get your friendly mechanic to give you a hand
Lastly, comp nut= normal thread sprocket nut= left hand thead
Impact wrench is OK to take off the nut. Don't use it to put it back on.
Old Sep 23, 2006 | 05:08 PM
glide's Avatar
glide
ORIGINAL: bikerbehaviorist
I wouldn't be using an impact wrench on the compensator nut at all either on or off. You run the risk of loosening up one of the stator magnets that are set in epoxy from the concussion of the impact wrench. It's happened to more than one person from the wrench and that means replacement.
Old Sep 26, 2006 | 11:37 PM
Shovel Ed's Avatar
Shovel Ed
<< I wouldn't be using an impact wrench on the compensator nut at all either on or off. >>
You are right, and using an impact wrench on a compensating sprocket it may also have effects on the wheels inside. When removing a compensating sprocket you should have a homemade jam bar. (I can't take credit for this, I learned it in another site, Hawg Ryder Harley Tech Forum).
Old Oct 6, 2006 | 02:58 AM
bikerbehaviorist
I wound up using a cheater bar and the block for the compensating sprocket, and borrowed an impact for the clutch - thanks for the help!!
Next I am off to the frame shop.
BiggCliff412
Oct 17, 2017 06:22 PM
scoriden
Mar 27, 2013 04:40 PM
badfl97
Aug 1, 2012 10:03 PM
jdot
Shovelhead
Jul 28, 2009 01:48 PM
OneBlackFly
May 24, 2007 08:44 PM
