cams ???
Old Feb 5, 2011 | 08:39 AM
lagunatic's Avatar
lagunatic
Default cams ???
Iam thinking about cam change looking for a little more power.I have a 72 flh with a 74" engine all stock except for carb S&S E AND DRAG PIPE which Iam thinking about changing,pipes not carb.Iam looking for thoughts on cams.nothing to crazy just alittle more power, is it worth the trouble?
Old Feb 5, 2011 | 01:49 PM
sqdealgeorge's Avatar
sqdealgeorge
Try Andrews A grind and solid lifters No valve spring clearance required
Old Feb 5, 2011 | 02:34 PM
prodrag1320's Avatar
prodrag1320
andrews #2 would be a good choice too,
Old Feb 5, 2011 | 03:21 PM
TW's Avatar
TW
I think I had an Andrews "B" in my last Shovel. Not bad.
Old Feb 7, 2011 | 06:56 AM
TwiZted Biker's Avatar
TwiZted Biker
VThunder cams SHV 4001 and haunt ebay for a set of the new hyd. lifters for shovels . These are are made like evo lifters much better than the old ones see them regular for $100 a set . Andrews cams are ok but they don't make power till 2500 rpm and up so you don't get into the power band without a lot of shifting and high rpm's . The VThunder cams are for hyd. lifters and come on around 1200 to 1500 rpm , you feel it right off the line don't have to rev as much . The VThunder 4011 and 4021 are real good cams for heavier shovels but need high lift valve springs or collars installed .
Krazy8s
Jun 7, 2022 11:34 AM
InthewindMN
Apr 15, 2015 02:47 PM
Jeffro1964
Jan 16, 2011 08:26 AM
swampking
Exhaust System Topics
Aug 9, 2009 05:48 PM
broke joker
Jul 18, 2006 05:01 PM
